I am using rh10 on Windows 7. The righthand pane of the WinHelp output appears as white text on a black background the lefthand pane is normal, i.e., dark text on a white background. This is true regardless of what browser I use.
When I first began using RoboHelp for my project, I did not have this problem, so I must have inadvertantly changed a setting. How can I correct this problem?
Dan
Check Project Manager > Skins and double click the skin you use. RoboHelp opens the skin editor where you can set colours, images for the TOC, etc. My guess is that a setting is off somewhere in the skin editor.
Greet,
Willam
Willam,
Thank you for your reply. I just now found the problem: turns out that it was not a skin, rather I had the wrong style sheet selected in the WinHelp layout.
Dan
