The "Go To" setting in Slide Manager does not seem to be working properly. On a slide, I set "Go To" to go to a previous slide, but when you click the Next button for that slide on the Presenter playbar it continues to be linear and just advances to the next slide instead of going to the previous slide I set it to "Go To". Is the "Go To" setting controlling the Next button on the playbar? Anyone have this issue or know how to get this functionality to work properly?
'Go to slide' will automatically play the slide, you have set for a particular slide, when that slide ends. If you have set advanced by user option as yes, then at the end of slide, you have to click on play to traverse to the slide you have set at 'Go to slide'.
Next and previous buttons which are to the right of play button have no role in it, they will get you forward/backward as normal.
Vikram
Adobe Presenter Engg. Team
Vikram
Got it, thank you for the quick response!
Is it possible to configure the Previous and Next buttons in the playbar per slide? I saw that you can turn off the playbar per slide, which would be another option, but I do not have an ASA or subscription service so I don't have access to that functionality.
For playbar turn off option, you have to wait for Presenter 9 release. Previous/next buttons are not configurable.
