CFFTP with proxy
Jan 30, 2007 Jan 30, 2007
Hi !
I wanna make an ftp connection passing by a proxy but I don't manage to with cfftp tag. This my code :
<cfftp action="open" username="*****" password="*****" server="*****.com" proxyserver="proxerserverIP" passive="yes" port="8080">
And this the error I get in return :
An exception occurred when establishing a FTP connection.
The cause of this exception was that: java.net.ConnectException: Connection timed out: connect.
Can somebody help me please ?
Advanced techniques
535
Advocate ,
The default timeout is 30 seconds, but you can override this using the timeout attribute of the <cfftp> tag.. Try specifying some more value as timeout.. That may perhaps work...
Thanks for your answer Daverms.
I tryed with timeout=1000000 but the same error is returned. Moreover proxyserver seems not to be used because a request is sent directly to the ftp server and not to the proxy. Any other idea ?
Advocate ,
Hi Jack,
This error mainly occurs due to the uploads that takes more that 30 seconds.
Try like this by putting the following statement
<cfsetting requestTimeOut = "120">
I believe this will probably work...
The same error again :'(
Have you ever used cfftp with a proxy ?
Advocate ,
Seems strange 😞 ....
Well.. If you can get through in your Command Prompt the following...
ftp> open server_ip
then:
user > username@hostname proxyusername
password > pass
proxypassword > proxypass
Then... You can also passthrough the authentication via CFFTP too...
It doesn't work either... I will contact the administrator something may be badly configured.
Thanks for your help 😉
Documentation
