I have been getting disconnected from every Adobe Connect meeting I have hosted for the past 10 days. My clients cannot hear me for up to 30 seconds. This has never happened before in 5 years using Adobe Connect. Is there a known problem? Over the past few days my Internet provider has given me a new modem and brought new wiring into the building/my office and still the same problem exists. It makes no difference if I am plugged directly into my i-Mac or Macbook laptop, or whether I am using wireless. Any thoughts?
I don't know how this would be a connect issue, but I'm not saying it isn't. You can always check the Hosted Connect environment here: http://www.adobe.com/cfusion/adobeconnect/index.cfm?event=serverStatus
If you connect from another location, do you experience the same issue? If so, then it may be a Connect issue. If not, then it probably has something to do with your Internet provider or IT policies.
Jorma, thanks for the reply. Like you, I am convinced that it is my Internet provider. I am just so frustrated. As I mentioned, they have replaced everything they can ... the wire into the building and the modem. It is puzzling because I have never had this issue in the previous 15 months of being with them. None of my peers who provided training through Connect are having issues. Thanks so much for your input!
Are there others on the same network not having these issues? I suppose it could be a network card issue on your computer. You may want to check and see if there is a driver update for it or try a different computer, if possible. Just trying to eliminate all the suspects.
I didn't make that very clear. My peers around the country (not on the same network) who use Connect are not having these issues. One of them presents regularly but he doesn't experience the connectivity issues. I appreciate all of your good advice.
Ok,
Well it sounds like the issue is local to you. Good luck on the investigation to identify the culprit.
