Hi Team,
Currently we are facing an issue in Scheduled Tasks options in ColdFusion 10 while we attempting to schedule some tasks. We are using the same facility successfully in ColdFusion 7 Standard edition up to now and the Schedule Tasks works perfectly in that version.
Also the same Scheduled task option we have tested successfully in CF 10 Trial version (Developer Edition) before we purchased the license. Once we updated with the Standard License all schedules were deleted from the list which we scheduled in Trial Version and when we have tried several options to create new tasks, we continued to get the following message
Advance Scheduling support is not available in this edition of ColdFusion server.
Also as we have checked under Server Updates in CF 10, there is no available updates are listing. Kindly let us know is there any workaround on this issue.
Best Regard's
Madu
Hi Madu,
It was fixed in ColdFusion 10 update 1, please check if you have installed ColdFusion updates.
Priyank
Hi Madu,
Priyank
Hi Priyank,
Now it is working like a charm. No errors and able to create Shedule Task. Thank very much for the support and valuable information you provided.
Rgds,
Madu
Hi Priyank.
We are on Update 9 and still I am getting the same error as shown in Madu's post. I cannot even update the schedule through the CFSchedule tag.
This is our server information:
Server Product | ColdFusion |
Version | ColdFusion 10,282462 |
Edition | Standard |
Operating System | Windows Server 2008 R2 |
OS Version | 6.1 |
Adobe Driver Version | 4.1 (Build 0001) |
What solution do you suggest?
Can you please test this in your Dev server first, as you're already in update 9 just recreate the connector and run the schedule task.
Priyank
Hi Priyank.
What do you mean by recereating the connector?
This issue was fixed in update 1, so if you can run the utlity which is in ColdFusion10\cfusion\runtime\bin\wsconfig.exe, that will help you to re-create the connector with IIS. Make sure you run this utlility as Adminitrator.
Priyank
Hi Priyank. We ran the utility with the "All" option, but the error is still there when I create a recurring schedule. Also, the server version has not changed. It is same as the one I provided above. Is it normal?
Thanks.
