Hey,
I have CS3 which I need to instal from one mac to another. It already has been deactivated and installed again as well. But after entering serial number I can see window called Updade Check and here my serial doesn't work. Technical support does not longer support old versions so they can't help me. But I need to run CS3 on this mac anyway. Can I skip Update Check step anyhow? Or what can I do to run this? Problem is I already cannot even use it on previous machine 'cause it already has been deactivated.
Does anyone know what should I do in this situation?
skip the update check.
you can update each program directly after installing and activating, if you need.
I want to but there is no option for that. I can't go futher without it.
Actually I don't even need to update anything but it seems I have no choice
Nevermind. I've solve this problem. Discussion may be deleted.
Thank you.
you're welcome.
