1. Re: Which sequence preset for .mp4 movies
joe bloe premiere Apr 25, 2013 4:20 PM (in response to owiseone61755)Do this to create a sequence that matches your footage:
2. Re: Which sequence preset for .mp4 movies
owiseone61755 Apr 25, 2013 4:27 PM (in response to joe bloe premiere)Thank you but I'm not sure how you got to that screen shown in the picture. If I try and create a new project or a new sequence it immediately asks for the preset I would like to use to match my footage. If there's another way to get there can you explain a little more? Thank you so much.
3. Re: Which sequence preset for .mp4 movies
joe bloe premiere Apr 25, 2013 4:37 PM (in response to owiseone61755)When you launch Premiere and create a new Project, it asks you
if you want to choose from a list of Sequence Presets... just skip that step
by hitting Cancel, import your media, then do what is shown above.
4. Re: Which sequence preset for .mp4 movies
owiseone61755 Apr 25, 2013 5:20 PM (in response to joe bloe premiere)Okay, thanks. So if I load 30 movies into my project but I only want to work with 2-3 minutes from each film. How can I extract those clips without moving the whole movie into the timeline and cutting it there? Can I make smaller files of the scenes I need and then remove the complete films from the project?
5. Re: Which sequence preset for .mp4 movies
joe bloe premiere Apr 25, 2013 6:00 PM (in response to owiseone61755)So if I load 30 movies into my project but I only want to work with 2-3 minutes from each film. How can I extract those clips without moving the whole movie into the timeline and cutting it there?
The movies are mostly 720p .mp4's.
Take one of these 720p .mp4 files and create a new sequence.
Then you add the segments from all of the other clips in the preferred
order to the one sequence you now have created... editing.
Adobe Premiere Pro Help and tutorials
http://helpx.adobe.com/premiere-pro/topics.html
Getting Started with Premiere Pro CS6
http://www.video2brain.com/en/getting-started-with-premiere-pro
6. Re: Which sequence preset for .mp4 movies
owiseone61755 Apr 25, 2013 6:27 PM (in response to joe bloe premiere)I think I missed a step. Right now I don't have segments from the movies. Just the complete movies. So how do I get all the segments together. I don't know what the preferred order will be just yet. I want to extract all the 2-3 minute clips and get those into the project and then be able to load those onto the timeline and trim what I want.
7. Re: Which sequence preset for .mp4 movies
joe bloe premiere Apr 26, 2013 7:19 AM (in response to owiseone61755)I don't have segments from the movies. Just the complete movies. So how do I get all the segments together.
That's what you do with Premiere.
You select segments of various clips and put them
together in a particular order in one Timeline... editing.
Don't worry... just start pulling together the pieces you want to use.
You don't need to immediately determine what your preferred order
or durations will be. You can easily change it later... nonlinear editing.
Then... do just that.
Pick out the 2-3 minute segments you might want to use,
throw them all together on one Timeline, then start figuring
out what order, what to trim etc.
Required Reading:
8. Re: Which sequence preset for .mp4 movies
owiseone61755 Apr 26, 2013 8:04 AM (in response to joe bloe premiere)I guess what I mean is I don't want the 2-3 minute clips on the timeline initially. I want them in the project pane window and be able to pull them as needed into the timeline. I will have 30-40 clips and If I put them all right into the timeline it semms like they would be harder to work with. I'm not totally unfamiliar with premiere. I've done a few other projects but I was using clips that I filmed myself and each were not very long in length.
9. Re: Which sequence preset for .mp4 movies
joe bloe premiere Apr 26, 2013 8:14 AM (in response to owiseone61755)I want them in the project pane window and be able to pull them as needed into the timeline.
Load them into the Source Monitor, mark in and out points
to define the segment you want to include in your Timeline,
then hit 'insert', 'overwrite' or drag them to the Timeline.
You really should read about
Adding clips to sequences
Also:
10. Re: Which sequence preset for .mp4 movies
owiseone61755 Apr 26, 2013 8:29 AM (in response to joe bloe premiere)Okay, I will try that and I will read the information you linked as well. Thank you again for all the help! I'm excited to work on this project.
