1. Re: How do I cut on the red line?
joe bloe premiere Apr 26, 2013 5:42 PM (in response to owiseone61755) -
2. Re: How do I cut on the red line?
owiseone61755 Apr 26, 2013 5:46 PM (in response to joe bloe premiere)Thank you, and how do I shift everything to the right to insert a track in the beginning of the timeline?
3. Re: How do I cut on the red line?
owiseone61755 Apr 26, 2013 5:49 PM (in response to joe bloe premiere)What does track enabled mean? I have the clip selected in the time line and the red vertical line on the frame I want but I press cntrl-K and nothing happens.
4. Re: How do I cut on the red line?
joe bloe premiere Apr 26, 2013 5:52 PM (in response to owiseone61755)how do I shift everything to the right to insert a track in the beginning of the timeline?
Zoom out your Timeline, lasso-select all of the
clips you want to move... and slide them to the right.
5. Re: How do I cut on the red line?
joe bloe premiere Apr 27, 2013 6:03 AM (in response to owiseone61755)What does track enabled mean?
AND...
You really should at least glance at the information
in the links I have repeatedly posted for you that
specifically describe the things you are still asking.
http://forums.adobe.com/message/5270001#5270001
6. Re: How do I cut on the red line?
Kevin-Monahan Apr 26, 2013 5:59 PM (in response to owiseone61755)owiseone61755 wrote:
I'm not sure if you know this, but you do not need to shift clips to the right to insert a clip. You can just use an Insert Edit by clicking the Insert button in the Source Monitor. You can also drag the clip to the beginning of the Timeline, just press the Command key before letting go of the mouse.
Hope that helps,
Kevin
7. Re: How do I cut on the red line?
owiseone61755 Apr 27, 2013 8:41 AM (in response to joe bloe premiere)Okay, I got it to work. Awesome. I probably would have never figured that out! Thank you.
