Hello,
I'm following the tutorial for building a dashboard from Michael Chaize: http://www.adobe.com/devnet/flex/articles/build_first_dashboard.html
I've downloaded the sample_dashboard.zip
When I'm in the "Test Operation" tab >> Operation: getAllCompanyTotals(): Objects >> Test, i get the following error message:
InvocationTargetException:There was an error while invoking the operation. Check your operation inputs or server code and try invoking the operation again.
Reason:
Warning: mysqli_connect(): (42000/1049): Unknown database 'adobe' in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 44
Warning: mysqli_error() expects parameter 1 to be mysqli, boolean given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 122
Warning: mysqli_prepare() expects parameter 1 to be mysqli, boolean given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 82
Warning: mysqli_stmt_execute() expects parameter 1 to be mysqli_stmt, null given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 85
Warning: mysqli_stmt_bind_result() expects parameter 1 to be mysqli_stmt, null given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 90
Warning: mysqli_stmt_fetch() expects parameter 1 to be mysqli_stmt, null given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 92
Warning: mysqli_stmt_free_result() expects parameter 1 to be mysqli_stmt, null given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 98
Warning: mysqli_close() expects parameter 1 to be mysqli, boolean given in /Applications/MAMP/bin/mamp/CompanySalesService.php on line 99
/0/onResultUflex.messaging.messages.AcknowledgeMessagecorrelationIdclientIddestinationmessageIdtimestamptimeToLiveheaders bodyID5F460F6-58C5-4B14-9914-FD7380B1B728I5F06C85F-80FC-0B49-0250-00007CFDE483I0A3E50D9-AAF8-7649-9A45-00004F48D560136703959200
any help will be appreciated thanks!
You have to either deploy your app to a server or install a local/virtual server to test your app properly.
I can recommend xampp for a local installation.
