I apply MB Looks to Premiere Pro Adjustment Layer. However, there is no preview (black) in the MB Looks window. Anyone knows what could be the problem as it was working fine before...
Works fine here... CS6.0.3 / MBL 1.4
Did you update to version 2.1.0?
This fixes incorrect frame from PP.
http://www.redgiant.com/products/all/magic-bullet-looks/updates/#produpdate-2_1_0_2013-04-24
Yes, already updated to MBL 2.1.0. The thing is, it was working fine before and out of a sudden it started having this problem. I actually exprericed the same problem with Prodad Vitascene filter. No video shown in the Vitascene preview panel. Will reinstallting PPro helps? Any other idea?
Launch Pr from a Desktop or Start Menu shortcut and hold down the
Shift+Alt keys while it launches. Keep them pressed until the Welcome
screen shows. Doing that resets your Preferences and your Plug-in cache.
Jeff
Hi Jeff, I tried that out... problem still there.
Then the only thing I can think of is that you need to update your video card driver. Go directly to the manufacturer's web site to update; don't rely on Windows or update utilities to do it.
Jeff
Do you have a frame when MBL is dropped on a clip and not an adjustment layer?
Hi Ann, I do have a frame when I drop MBL directly onto the clip. But I can't get a MBL preview frame on the adjustment layer.
Aha, I just checked. I do not have a frame from an AL aswell. However the effect itself does work.
Think this must be a bug.
You might want to file a bug report with RG.
So, I guess the problem doesn't lies with PP after all. Will file a bug report to RG then. Thanks Ann...
I was having the same issue and the preview wasn't appearing with AVCHD and .mts files. I simply reinstalled Looks and it seems to have resolved the issue.
