1. Re: Help with Titles in Premiere Pro
Bill Hunt Apr 27, 2013 3:56 PM (in response to bigmanfontu)In the case of the Export, and since the Title has a Transparent background, it sees nothing, without a Clip of some sort below it, and show black.
While I have not tried it, can you Export with an Alpha Channel, and get the Transparency?
Good luck, and maybe others have found a good way to Export a Title with Transparency.
Hunt
2. Re: Help with Titles in Premiere Pro
Ann Bens Apr 27, 2013 4:07 PM (in response to bigmanfontu)For transparancy:
Export as an avi, codec set to none and bitdepth 32.
For mac that will be mov, animation codec and depth set to 32.
3. Re: Help with Titles in Premiere Pro
bigmanfontu Apr 28, 2013 7:53 AM (in response to Ann Bens)Let me try that. But if the video itself is long. Something like an hour and a half..and I export using no codec set, won't the video file be gigantic?
4. Re: Help with Titles in Premiere Pro
Steven L. Gotz Apr 28, 2013 8:41 AM (in response to bigmanfontu)Let me ask ...
Are your titles contantly in motion, meaning that a large file is probably your only shot, or would it suffice to turn your carefully crafted titles into PNG files that could easily be used in After Effects?
I find your question a bit odd because I find it much easier to create my titles in After Effects than in Premiere Pro if there is going to be any motion. For still titles I can surely see the advantage of Premiere Pro's titler.
When I want to take a title into After Effects, I merely export as a PNG and include the Alpha channel.
5. Re: Help with Titles in Premiere Pro
JSS1138 Apr 28, 2013 8:53 AM (in response to bigmanfontu)Seems like you're going about things the hard way, here. Why not just create the titles in AE to begin with?
6. Re: Help with Titles in Premiere Pro
bigmanfontu Apr 28, 2013 5:34 PM (in response to JSS1138)Great question. Well, unless I completely overlooked something, After Effects doesn't appear to have the same "playhead" capabilities that Premiere has. In Premiere it's super easy getting these titles synced because of that feature. It let's you scrub back and fourth and even does so with audio. Very convenient. But I can't find it in After Effects?
Also in regards to exporting the media, I tired the avi settings and the file was super huge. However, I also tried the mac settings, even though I'm using Windows, and exporting via quicktime worked the best.
