I want to put a drop dowm box in my web contact form that if someone selects Office, the form data goes to email address one. If selects reception, data goes to email 2. Is it doable? Seems like BC can only forward emails.
BC does not forward emails. I do not know what you mean by that.
If you have one of the higher plans when a form is filled in..
1. An Auto responder goes to the person who filled in the form to their email. (Only one person)
2. A workflow notification can be triggered going to the site role specified on the work flow.
If you on a webbasic plan or choose to implement this method:
http://kb.worldsecuresystems.com/kb/setting-form-email-using-web.html
What you will need to do is is have the dropdown and some javascript and change the form action to have a different email to send too.
Hi Liam,
Thx so much for your reply. I would love to implement the method you mentioned. I had a try it, but I could not figure out what to put in form action. I tried the one in the example, "/Default.aspx?A=Form&Email="+my email, it went to home page with "/Default.aspx?A=Form&Email=" in the url, and the style of my home page is a bit strange. But more important, it put everything in the form including CaptchaV2, CaptchaTV2, CaptchaHV2. I dont understand what they are. Can I set what is being send?
I also tried the action that the form automatically generated, "/FormProcessv2.aspx?WebFormID=10254&OID={module_oid}&OTYPE={module_otype}&EID={module_eid}&CID={module_cid}"+"&A=Form&Email="+my email, but the form did not send to my email. Any ideas?
You need to read the link, You not really followed that as its outlined at all there. Do that first, get that working. Then you can look to extend it with javascript to alternate the emails based on that dropdown.
