Hi RoboFan
Try this:
ms-its:CHMFileName.CHM::/TopicName.htm
Of course you would need to first display the topic inside
the .CHM so you know what its name is and the actual path. What is
listed above assumes the topic is in the root level. If it's inside
a folder, it would look something like this:
ms-its:CHMFileName.CHM::/FolderName/TopicName.htm
I would assume that this should work as long as the .CHM is
inside the same folder as the document. If not, you may need to
specify a path to the .CHM file. In that case, I would think it
would need to be something like:
ms-its:c:\SomeFolder\CHMFileName.CHM::/TopicName.htm
Hopefully this helps... Rick
