Hello Brian,
Adobe RoboHelp Server 6 should connect to ODBC sources just
fine. The minimum system requirements include Oracle 9i, Oracle
10g, or SQL Server 9.0. These minimum system requirements simply
mean that we have tested and fully support integrating Adobe
RoboHelp Server 6 in these environments.
In theory, all ODBC sources should respond the same way to
ODBC requests, so any ODBC compliant datasource should (again, in
theory) work. Adobe Technical Support will not be able to support
environments outside of the minimum system requirements.
If you would like to see MySQL added to the minimum system
requirements in the future, please submit a feature request via
this web page:
http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform.
Thank you,
Bobby Walker
