9 Replies Latest reply: May 1, 2013 1:08 PM by kglad RSS
    Math.sin(Math.PI)
    Ron Colmen Community Member
      It's a circular pre-loader. When I add the "SecondHalf" the preloader doesn't work and gives an error saying the script is causing the flash player to run slowly. How can I fix this?
      This code is in:  _root.first_mc._second_mc
      previewImage.onLoadProgress = function(targetMC, lBytes, tBytes) {
      //FirstHalf
      //This works only without "SecondHalf"
                percentDone=Math.round((lBytes / tBytes) * 100);
                _root.loaderPsnt_tx.percentDisplay.text = percentDone + "%";
      //SecondHalf
      //This is not working
            _root.mc_mask.clear();
            _root.mc_mask.beginFill(0xff0000, 100);
            _root.mc_mask.lineStyle(1, 0xff0000, 80);
            for (i=0; i>=c; i--) {
               x = Math.sin(Math.PI/90*i)*mask_ra;
               y = Math.cos(Math.PI/90*i)*mask_ra;
               _root.mc_mask.lineTo(x, y);
            _root.mc_mask.endFill();
            c = Math.round(percentDone * (-1.84));
      previewImage.onLoadStart = function(targetMC) {
                _root.loaderPsnt_tx._visible = _root.circle._visible = _root.mc_mask._visible = true;
                _root.circle.setMask(_root.mc_mask);
                var mask_ra:Number = (_root.circle._width / 1) * -1;
                var c:Number = 0;
                var percentDone:Number = 0;
      previewImage.onLoadComplete = function(targetMC) {
                _root.loaderPsnt_tx._visible = _root.circle._visible = _root.mc_mask._visible = false;
        • 1. Re: Math.sin(Math.PI)
          kglad CommunityMVP
          c isn't defined when your loadprogress first executes.
          try:
          //FirstHalf
          //SecondHalf
                    var c:Number = 0;
          • 2. Re: Math.sin(Math.PI)
            Thanks Kglad.
            Got rid of the error message now but still the masking is not working as expected. Any idea why? When I use this on the root and it works but it doesn't work in _root.first_mc._second_mc?
            percentDone + "%"; works though.
            • 3. Re: Math.sin(Math.PI)
              kglad CommunityMVP
              well, that code doesn't look like it would do anything useful.  what is it supposed to do?
              create wedge-shaped mask that increases from 0 degrees to 360?
              • 4. Re: Math.sin(Math.PI)
                Yes.
                The preloader works fine when both the code & the MCs are on the root. Is this issue related to the code being in _root.first_mc.second_mc and the preloader being on the root?
                • 5. Re: Math.sin(Math.PI)
                  kglad CommunityMVP
                  where's your moviecliploader and listener defined and what code is used to add the listener?
                  • 6. Re: Math.sin(Math.PI)
                    Moviecliploader and listener are defined in the same frame on _root.first_mc.second_mc
                    var previewMCL:MovieClipLoader = new MovieClipLoader();
                    var previewImage:Object = {};
                    previewMCL.addListener(previewImage);
                    ///doSomething
                    RefLO.onComplete = function(file:FileReference):Void {
                    ////doSomething
                              previewMCL.loadClip(imageFile,tl.targetMC);
                    • 7. Re: Math.sin(Math.PI)
                      kglad CommunityMVP
                      mask_ra is undefined in onLoadProgress.
                      use:
                      var mask_ra:Number;
                      //FirstHalf
                      //SecondHalf
                               mask_ra = (_root.circle._width / 1) * -1;
                                var c:Number = 0;
                      • 8. Re: Math.sin(Math.PI)
                        Thanks Kglad!!
                        • 9. Re: Math.sin(Math.PI)
                          kglad CommunityMVP
                          you're welcome.
