I am composing a book and I am having trouble with footnotes using Frame Maker 8.
Two footnotes on the same page, a left page, are particularly long. The first one appears on the next right page about three inches up. The footnote two footnotes later is also long, but not so long that it will not fit on that right page. However, the program is automatically moving that footnote to the next left page. This is problematic, because we want the reader to be able to read the footnote without having to flip back and forth. It gets particularly bad after that, so that footnotes in that area are appearing two or three pages after the page containing the footnote indicator.
I tried searching help for information, but I haven't been able to figure out how to fix it. Is there a way to correct this?
Better yet, is there a way to structure the Master Pages or Styles in a way so that the footnote text will appear either on the same page (on a right page) or on the same or next page (for a left page)?
In Format > Document > Footnote Properties ...
what is
Maximum Height Per Column:
set to?
... and is any other page content preventing the FN stack from getting that high?
I just figured that out. The maximum height was set too low. I was trying to use the paragraph styles to keep the footnote with the previous one, but that was not working.
My problem is fixed for the time being.
But, I would still like to know if anyone knows if there is a way to automatically ensure that footnotes appear either on the left page or accompanying right page, even if doing that adds white space.
> ... automatically ensure that footnotes ...
If you want automatic, you're pretty much limited to what FM provides, and FM's footnote functionality hasn't been enhanced to any great degree in the last decade or so.
The feature most commonly requested is endnotes.
Adobe telegraphed the answer "fuggedaboutit" when they documented how to simulate those by using the long-standing Xref hack. Footnote text at end of flow in numbered paragraphs. References earlier in body are superscripted Xrefs by paranum.
Using Xrefs,
to numbered paras in text frames,
inside anchored frames,
anchored to bottom-of-column,
you can make what appear to be footnotes do more or less what you want, but it is some distance removed from being "automatic".
Why would that xref process be better than an endnote marker, which allows auto creation of the endnotes via an index of markers. No need for the xref process described...
-Matt
Unless you are describing something new with FM10 or 11, I'm guessing that the endnote display text would be the Marker Text.
The one time I looked at doing a project that way, the elemental plaintext nature of the marker text quickly became a problem (no Xrefs in that text, no URLs in that text, no character formatting, etc.).
It think this is covered in "the bible" - Unstructured FM8 (now updated for FM11) put out by Scriptorium - cheap PDF copies are for sale from them of the FM8 book, but I think we're still waiting for PDFs of the FM11 one to be made available. You can also check the Scriptorium wiki which is based on the FM8 book.
