Our plattform is:
Coldfusion 9.01
Windows 2003
IIS 6
We did not upload any code or did anything on the server. Our site was unresponsive and we restarted the server.
After that we are getting following when hitting the pages that try to accdess cookies, also I can't access coldfusion admin that was running on coldfusion built in server.:
Any ideas?
05/01 17:24:07 error ROOT CAUSE:
java.lang.IllegalAccessError: tried to access method coldfusion.runtime.NeoPageContext.isUnderCFThread()Z from class coldfusion.runtime.CookieScope
at coldfusion.runtime.CookieScope.bindName(CookieScope.java:90)
at coldfusion.runtime.CookieScope.bindAsScaler(CookieScope.java:81)
at coldfusion.runtime.NeoPageContext.SymTab_setSplitNameInMap(NeoPageContext.java:1389)
at coldfusion.runtime.NeoPageContext.SymTab_setValidatedSplitNameInString(NeoPageContext.java:1355)
at coldfusion.runtime.NeoPageContext.SymTab_setValidatedDottedName(NeoPageContext.java:1437)
at coldfusion.runtime.NeoPageContext.setValidatedAttribute(NeoPageContext.java:571)
at coldfusion.runtime.NeoPageContext.setAttribute(NeoPageContext.java:434)
at coldfusion.runtime.NeoPageContext.setAttribute(NeoPageContext.java:427)
at coldfusion.runtime.SecurityScopeTracker.setSecurityCookie(SecurityScopeTracker.java:126)
at coldfusion.runtime.SecurityScopeTracker.logout(SecurityScopeTracker.java:85)
at coldfusion.tagext.security.LogoutTag.doStartTag(LogoutTag.java:20)
at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2722)
at cflogin2ecfm1599616868.runPage(C:\work\ColdFusion\cf9_u1_final_hotfix\cfusion\wwwroot\CFIDE\administrator\login.cfm:11)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416)
at cfApplication2ecfm1920815415._factor5(C:\work\cf9_u1_final_hotfix\cfusion\wwwroot\CFIDE\administrator\Application.cfm:210)
at cfApplication2ecfm1920815415._factor9(C:\work\cf9_u1_final_hotfix\cfusion\wwwroot\CFIDE\administrator\Application.cfm:202)
at cfApplication2ecfm1920815415.runPage(C:\work\cf9_u1_final_hotfix\cfusion\wwwroot\CFIDE\administrator\Application.cfm:1)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:33)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:297)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:94)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
at coldfusion.CfmServlet.service(CfmServlet.java:201)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
javax.servlet.ServletException: ROOT CAUSE:
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70)
java.lang.IllegalStateException
at jrun.servlet.JRunResponse.getWriter(JRunResponse.java:205)
at jrun.servlet.JRunResponse.sendError(JRunResponse.java:597)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:328)
Have you applied any Cumiltive hotfix or Security hotfix for ColdFusion 9.0.1
Priyank
