Hey!
I am using the slider that came with a default BC template (I believe it is the nivo slider), and it gives me options for Item Name, URL, & Image.
The URL that the slider links to currently has to be relative to the web app's directory, so for example I can only link to mydomain.com/slider/somepage when really I just want to link to mydomain.com/somepage.
Is there a way around this?
It looks like the template you are using uses Web Apps for the slider and the layout controlling that slider simply lists the {tag_image} and that tag wraps the URL of the web app detail view around the image. There are two ways around this...
The easiest, most hands-off way is to just add 301 redirects to the content you really want. Let's say the slider links to "/slider/somepage" which is the detail view of the web app item but you want it to goto some other content instead...
What if you try using a URL that references your root... for instance in the URL field if you wanted mydomain.com/somepage just use "/somepage" or if you wanted mydomain.com/somefolder/somepage just use "/somefolder/somepage"
Already tried it, as well as the other tricks like ../ and so on. It just appends exactly whatever I put into the URL field to 'mydomain.com/slider/', so if I put 'somepage' it links to mydomain.com/slider/somepage and if I put '/somepage' it links to mydomain.com/slider//somepage (with two slashes).
I could rename the slider's web app URL from 'slider' to 'pages' or something similar, then actually create a directory called 'pages' and move 'somepage', etc into this folder. It just is such a sloppy workaround.
Also I am actually using AnythingSlider. It came with the BusinessCatalyst Adora template.
The caveat is that everytime you add a new slider you must add a 301 Redirect again but you don't have to muck with the web app layout much. This additional step might be too much for a client to remember/do each time so there's another way.
The second way is to add a new field to your Carousel Web App and to edit the layout of the Carousel List View to include the new URL field we add.
<li>{tag_image}</li>
<li><a href="{tag_contenturl}">{tag_image_nolink}</a></li>
Good luck. Let me know how it goes.
