Locked
Can install flash player OS10.8.3
May 01, 2013 May 01, 2013
I have closed virus protection and firewall and uninstalled flashplayer and then restarted and closed Browser and the installer will show download then show lock and show error when it goes to install.
1.2K
May 02, 2013 May 02, 2013
Try this installer http://fpdownload.macromedia.com/get/flashplayer/current/licensing/mac/install_flash_player_11_osx.d...
If you still have problems, please post a screenshot of the error you are getting.
Just said the installation failed.  Get Support    Done
May 03, 2013 May 03, 2013
Hi Pat,
Still having trouble. I appreciate your helping.
Cheers,
Mort
I have asked a member of the Flash Player team to look into this, but you may have to wait until after the weekend.
Adobe Employee ,
May 07, 2013 May 07, 2013
Hi Mort,
Could you post a copy of your Flash Player install log for us to take a look at?
Where do I find the Flash Player installation log on the Macintosh?
Chris
May 08, 2013 May 08, 2013
Hi Chris   I had some problems with my HD but have performed first aid and it says it's ok now.  Here is the log.  Hope this is right and hope it helps.
Mort
2013-05-07 04:05:14 +0000 ---------- log start ----------
2013-05-07 04:05:14 +0000 All install checks pass
2013-05-07 04:05:14 +0000 [install started]
installer: Must be run as root to install this package.
chmod: /Library/LaunchDaemons/com.adobe.fpsaud.plist: No such file or directory
chmod: /Library/Application Support/Adobe/Flash Player Install Manager/fpsaud: No such file or directory
sudo: no tty present and no askpass program specified
2013-05-07 04:05:15 +0000 [install completed]
2013-05-07 04:05:15 +0000 ----------  log end  ----------
2013-05-07 04:07:40 +0000 ---------- log start ----------
2013-05-07 04:07:40 +0000 All install checks pass
2013-05-07 04:07:59 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-05-07 04:07:59 +0000 [install started]
2013-05-07 04:08:00 +0000 [install completed]
2013-05-07 04:08:00 +0000 [install failed]
2013-05-07 04:08:07 +0000 ----------  log end  ----------
Adobe Employee ,
Thank you for the log.  First thing I'd try is to fix permssions using Apple's Disk Utility.
http://support.apple.com/kb/ht1452
If that doesn't help, the next thing I'd try is to force the installer to run at the highest permission level.  You can do that using these steps:
1. Download and mount the installer from: http://fpdownload.macromedia.com/get/flashplayer/current/licensing/mac/install_flash_player_11_osx.d...
2. Start the Terminal application in your /Applications/Utilities folder
3. type: cd /Volumes/Flash\ Player/Install\ Adobe\ Flash\ Player.app/Contents/MacOS   (please note that the slash direction is important)
4. type: sudo ./Adobe\ Flash\ Player\ Install\ Manager
You'll be prompted for your password and then the installer should start up.  If you are unfamilar with Terminal or run into problems please send email to ccampbel@adobe.com and we can setup a quick desktop sharing session so I can take a look at what's going on.
