FDS and Tomcat
Avatar
Level 3
Hi all,
I'd like to know if there's some restriction regarding FDS
working over Tomcat.
Can persistent connections been stablished?
Is there some other problem?
thanks
Avatar
Level 1
Hi--
The only issue I've found is that, in order to use the data
management features of Flex you need to install JavaTransaction
support in Tomcat. This article has more info:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=6b82874f
An abbreviated version:
Download the latest JOTM jars (Note: you may have to add
".gz" to the downloaded file for it to open properly in winzip,
i.e. rename jotm-2.0.10.tar to jotm-2.0.10.tar.gz)
Place the following jars from the JOTM dowload in your
$TOMCAT_HOME/common/lib/ directory so that both Tomcat and your web
application will see them:
* commons-cli-1.0.jar
* connector-1_5.jar
* howl.jar
* jotm.jar
* jotm_jrmp_stubs.jar
* jta-spec1_0_1.jar
* jts1_0.jar
* objectweb-datasource.jar
* ow_carol.jar
* xapool.jar
Edit your context.xml file in $TOMCAT_HOME\conf and add the
following text:
<Transaction
factory="org.objectweb.jotm.UserTransactionFactory"
jotm.timeout="60"/>
That's it. Just restart your Tomcat and you should be able to
run the samples with the FDS download.
Avatar
Level 3
Hi.. thanks for answering!
I got to install it :)
I was afraid protocols like RTMP wouldn't work on
Tomcat
