2 Replies Latest reply on May 7, 2013 12:30 PM by rsimms1992
    Percentage Calculation
      Hi, I need help creating a calculation field that would find the percentage of values obtained from radio button groups in acrobat 9.0.
      I basically have ten radio button groups (ODIO1, ODIO2, ODIO3, ODIO4, ODIO5, ODIO6, ODIO7. ODIO8, ODIO9, ODI10).  They
      each have six radio buttons/chocies that correspond to button values of 0,1,2,3,4, and 5.
      I essentially need a calculation field that would display the percentage of the groups with the equation = (SUM(ODI01 - ODI10)/50) * 100%.
      This would give me a value from 0-100%.
      I have little experience in using Javascript, so any help in creating a Javascript to use this equation is greatly appreciated.
      Thank You!
        • 1. Re: Percentage Calculation
          try67 MVP & Adobe Community Professional
          If you're using a percentage field the result needs to be a number between 0 and 1, not 100...
          Anyway, this code replicates your formula:
          var total = 0;
          for (var i=1; i<=10; i++)
              total += +(this.getField("ODIO")+i).value;
          event.value = (total/50) * 100;
          • 2. Re: Percentage Calculation
            rsimms1992 Level 1
            Thanks for the feedback.
            I understand what you mean with getting a formula with a value between 0 and 1.  How would I need to change the formula to do this?
            Also how can i factor into the "total" line the sum of the total value of all the radio buttons groups?
