I am using a couple of web app fields to style other web app edit fields hidden or revealed.
eg class="{tag_hideReveal 1}" will output class="hide" or class="reveal".
When the web app is created the hideReveal values were set. I am trying to update the values in hidden fields using the edit page.
However they always return the current value of the field, even if I physically write the opposite into the edit page code. I don't want this value to be set be customers, it must be hidden.
How can I make these swap? Will jquery or javascript do it? Basically if one is reveal, I will want it to be hide, and vice versa.
Edit page code
______________________________________________________________________________________________________________
<div class="{tag_hideReveal 1}">
<label>Do you, the host, agree to the Term and Conditions and wish to make an offer to the visitor?</label>
<input type="checkbox" name="CAT_Custom_255715" id="CAT_Custom_255715_0" value="Yes" />Yes</div>
<input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="hide" /><!-- was reveal, now I want it be hide -->
<div class="{tag_hideReveal 2}"><label>Do you, the visitor, agree to the Terms and Conditions and accept the offer from the host?</label>
<input type="checkbox" name="CAT_Custom_255716" id="CAT_Custom_255716_0" value="Yes" />Yes</div>
<input type="hidden" name="CAT_Custom_257331" id="CAT_Custom_257331" class="hideReveal" value="reveal" /><!-- was hide, now I want it be reveal -->
Outputted code
<div class="reveal">
<input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="reveal" /><!-- was reveal, now I want it be hide -->
<div class="hide"><label>Do you, the visitor, agree to the Terms and Conditions and accept the offer from the host?</label>
<input type="hidden" name="CAT_Custom_257331" id="CAT_Custom_257331" class="hideReveal" value="hide" /><!-- was hide, now I want it be reveal -->
Thanks!!
I'm just a little confused. You are using these tags on the EDIT item layout for the web app? But you also want to reveal/hide some content based on their selection while on the edit layout view?
Why are you using two {tag_hideReveal} tags (ie- {tag_hideReveal 1} and {tag_hideReveal 2}? If you intend for it to be one or the other, you should use one tag {tag_hideReveal} and the value will be either "hide" or reveal". So then your code could be:
<div class="{tag_hideReveal}">
<input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="{tag_hideReveal}" /><!-- was reveal, now I want it be hide -->
</div>
And use CSS to hide .hide and you can do nothing with the .reveal class:
.hide { display: none; }
This way that DIV will be shown when hideReveal is set to reveal and be hidden when it's set to hide.
I might be missing something from your explanation. Let me know if I am getting the gist.
I know, it is a bit confusing. The reason being is that we have 2 customers using the smae edit form. Therefore, when one customer has editied it, I want the fields to update and be ready for th secod customer to use.
Correct, .hide is display: none, and .reveal has no CSS and so is shown.
The essential info is how to change the existing value of {tag_hideReveal} to the other value, in a hidden input. When the page loads, the value of the input is updated to the current value, regardless of what values I enter in the Edit code.
I think it must be javascript.
Anyway, thanks for looking!
I added this to the head - it seems to work.
Thank you!!
<script src="//ajax.googleapis.com/ajax/libs/jquery/2.0.0/jquery.min.js"></script>
<script type="text/javascript">
$(document).ready(function()
$("#CAT_Custom_257330").val("hide");
$("#CAT_Custom_257331").val("reveal");
</script>
