I have installed ColdFusion 9.1 on a 64-bit server running Windows 2008 R2. I am using IIS 7.5.
When I try to access the following URL http://localhost/myhousing/security/login_admin.cfm I get the following error. Is there a patch available for CF 9 to resolve this error?
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
An exception occurred when instantiating a COM object.
The cause of this exception was that: java.lang.RuntimeException: Can not use native code: Initialisation failed.
The error occurred in C:/inetpub/wwwroot/MyHousing/Application.cfm: line 22
20 : <CFINCLUDE template="lib/housing_functions.cfm">
21 : <CFSET Application.obj_name = "UserInfo325DLL.UserClass">
22 : <CFOBJECT name="obj" action="create" type="com" class="#Application.obj_name#">
23 : <!------------------------------------------------------------------->
24 : <!--- END OF CONFIGURATION FILE --->
Resources:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; WOW64; Trident/5.0)
Remote Address ::1
Referrer
Date/Time 08-May-13 01:49 PM
Stack Trace (click to expand)
at cfApplication2ecfm293894775.runPage(C:/inetpub/wwwroot/MyHousing/Application.cfm:22) at cfApplication2ecfm293894775.runPage(C:/inetpub/wwwroot/MyHousing/Application.cfm:22)
at com.linar.jintegra.NativeObjRef.<init>(Unknown Source)
at com.linar.jintegra.Dispatch.createDispatch(Unknown Source)
at com.linar.jintegra.Dispatch.<init>(Unknown Source)
at com.intrinsyc.typeInfo.IMacroViewerProxy.<init>(IMacroViewerProxy.java:32)
at com.intrinsyc.typeInfo.MacroViewer.<init>(MacroViewer.java:90)
at com.intrinsyc.typeInfo.MacroViewer.<init>(MacroViewer.java:69)
at com.intrinsyc.typeInfo.InterfaceInfoFactory.getInfoGivenPROGID(InterfaceInfoFactory.java:50)
at coldfusion.runtime.com.ComProxy.<init>(ComProxy.java:114)
at coldfusion.runtime.com.ComProxyFactory.getProxy(ComProxyFactory.java:41)
at coldfusion.runtime.ProxyFactory.getProxy(ProxyFactory.java:65)
at coldfusion.runtime.CFPage.createObjectProxy(CFPage.java:4947)
at coldfusion.tagext.lang.ObjectTag.doStartTag(ObjectTag.java:427)
at coldfusion.runtime.CfJspPage._emptyTcfTag(CfJspPage.java:2722)
at cfApplication2ecfm293894775.runPage(C:\inetpub\wwwroot\MyHousing\Application.cfm:22)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.CfincludeFilter.include(CfincludeFilter.java:33)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:94)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
at coldfusion.CfmServlet.service(CfmServlet.java:200)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Did you get any idea...?
You are able to resolve the issue ?
Let's narrow down the problem by substituting the variable with the value directly on the cfobject tag.
<CFOBJECT name="obj" action="create" type="com" class="UserInfo325DLL.UserClass">
... and see if that works.
Another thing you might want to check if this is correct, UserInfo325DLL.UserClass.
