You have tripped over one of the "to do" list items for a
future version. It's kludgy but the workaround is to insert
"slience" for the slide equal to the length of your FLV. You can
find that out by selecting the FLV in Windows Explorer and the
length will show up in the properties. You insert the silence by
going to the Presenter menu in PowerPoint, Select Audio Editing.
Have your cursor at the beginning of the slide where you want to
add silence. Click Insert Silence and put in the length of seconds
for the FLV. Save it and Publish. This should work fine on a
Connect Server. I believe FLVs do not work on a Windows 2003
server. Here's a Tech Note on the subject with a workaround
http://www.adobe.com/go/tn_19439
Another item that is sometimes necessary is to make sure your
FLV is injected with metadata. I have a tutorial on my website
which explains this.
www.showmethedemo.com
Hopefully that will help.
John
John Daigle
Adobe Certified Connect/Captivate/RoboHelp instructor
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Newport, Oregon
