1. Re: Where can I find the CAPS LOCK functionality to disable the shortcut
Noel Carboni May 15, 2013 8:23 AM (in response to Mattmcquiff)Look in Preferences - Cursors.
Make sure to close/quit Photoshop after making the change, to ensure your preference setting is stored on disk.
-Noel
2. Re: Where can I find the CAPS LOCK functionality to disable the shortcut
Mattmcquiff May 15, 2013 8:46 AM (in response to Noel Carboni)I found that reverses the way it behaviours but Caps Lock still toggles it. What it not to toggle so that its always ready from whetever program I am using.
3. Re: Where can I find the CAPS LOCK functionality to disable the shortcut
Noel Carboni May 15, 2013 11:37 AM (in response to Mattmcquiff)You're saying it doesn't come up set the way you like it?
Funny... I've never had a problem with that. In my case Photoshop has always come up for me with the brush-size cursor.
-Noel
4. Re: Where can I find the CAPS LOCK functionality to disable the shortcut
TLL... May 15, 2013 11:47 AM (in response to Noel Carboni)I think the OP is saying hitting the caps lock turns off the brush cursor - and it does regardless of what app your in @ the time. It's a 'keyboard thing' and I don't think there's a way around that...
5. Re: Where can I find the CAPS LOCK functionality to disable the shortcut
Noel Carboni May 15, 2013 2:42 PM (in response to TLL...)I guess I just normally have the Caps Lock functionality off most of the time naturally, but I can see that if one's workflow led them to leaving it on sometimes it would end up needing changing when they got back in Photoshop. But is that different than pretty much any other app where text would be typed?
-Noel
