1. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Carl SunApr 19, 2013 12:24 AM (in response to Jouke-Poppe)
Which extensions have you installed? Which OS are you using? Have you updated Extension Manager to the latest version (6.0.5.9)?
2. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Jouke-Poppe Apr 19, 2013 1:34 AM (in response to Carl Sun)Flexilayouts 2 from extendstudio and I am running my pc on windows 7 ultimate. Extension manager version is the latest version
3. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Doenit May 9, 2013 6:30 AM (in response to Jouke-Poppe)I'm sitting with the same problem. Sucsessfully installed extension Manager 6.0.5. Working with DW CS5 on Mac OS x 10.8. The option of Extension Manager does not display under the extesion tab, neither can I find it any where els. Help please
4. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Carl SunMay 9, 2013 6:18 PM (in response to Doenit)
Each version of Extension Manager only installs/manages extensions for the same suite of products. EM CS6 only installs extensions for DW CS6. To install extensions for DW CS5, you should launch EM CS5 to install it. Note that you have to update EM CS5 to 5.0.3 before you launch EM CS5 in Mac 10.8, otherwise EM CS5 will crash due to Mac API change. You can use Adobe Application Manager to update EM CS5 or download and run http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_0_3_mul_AdobeUpdate.dmg which can be found at http://www.adobe.com/downloads/updates/.
5. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Carl SunMay 9, 2013 6:38 PM (in response to Jouke-Poppe)
Have you run the .air file in the zip file after extension installation?
6. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Jouke-Poppe May 16, 2013 11:55 AM (in response to Carl Sun)Carl, what do you mean with .air file, where can I find this file. I have DW6 installed, EM6 installed , everything the latest version but neither of the extensions are working. I am doing something wrong I am sure but what. Hope you can help me
7. Re: Extension manager installed correctly (it seems so) but the extentions in DW6 are not working at all
Carl SunMay 16, 2013 7:55 PM (in response to Jouke-Poppe)
I downloaded the FlexiLayout 2.1 extension. It's a zip file. In addition to the mxp file, it also contains FlexiLayout2ProEditor.air and install_steps.txt. The install_steps.txt said that after installing the extension, you also have to install the FlexiLayouts 2 Editor app by running the .air file. Please follow the steps in install_steps.txt.
