1. Re: Smart Object Update Script?
PECourtejoie May 17, 2013 6:40 AM (in response to d0brin)Hello!
What do you mean by refresh? Take a look at these script that might do what you want: http://viget.com/inspire/linked-smart-objects-in-photoshop or http://canlinkit.com/
2. Re: Smart Object Update Script?
JJMack May 17, 2013 7:07 AM (in response to d0brin)There is nothing to refresh imbedded Smart Object are copies independent stand on their own. If you want to update the imbedded smart object you can. However you need to somehow create a process that will record what smart object layers in a document contain. So when you update the original image you can reconcile you database query it for document that contains the copies in smart object layers. Then kick off a process to update the documents hit that will replace the contents of the involved smart object layers.
3. Re: Smart Object Update Script?
PECourtejoie May 17, 2013 7:50 AM (in response to JJMack)JJ, did you take a look at the links I provided?
4. Re: Smart Object Update Script?
JJMack May 17, 2013 8:53 AM (in response to PECourtejoie)I knew about that and also know that it has many limitations or problems. The whole subject is quite complex. Not something that is easily addressed.
