In Flash builder 4.7 64 bit I have a project that has 5 or 6 different debug/run configurations.
For instance I have 2 Google Android Configurations that run in the simulator - one is for a Galaxy Tab and one for a Fascinate.
However - when I set the device for the Fascinate configuration to Fascinate - it also changes the device on the Galaxy Tab configuration to the same device.
Is this a bug?
I would like to give this a bump. I am having the same issue. This was not a problem in flash builder 4.6.
I am also experiencing this issue. It certainly did not happen in 4.6. I even tried to manually edit the .lauch files in workspace/.metadata/.plugins/org.eclipse.debug.core/.lauches and it still wouldn't recognize the changes. I do not want to have to manually change which device I am testing on every time I need to switch between phones and tablets. I have had to go back to 4.6 because of this issue. Please fix ASAP.
It definitely is a bug and Adobe really needs to get on fixing it. There is a way to work around it, though, which will at least make it so that the bug can be lived with. I posted the answer in response to another thread in the forum. It can be found at http://forums.adobe.com/thread/1226494. Hope it helps!
