From what I have read the silent auto update feature is supposed to use the system account so the user can be a non-admin and it will still silently update in the background. However the users are getting the following error message popping up:
Adobe Flash Player 11.7 Installer
The installation encountered errors:
You must have administrative privileges to install Adobe Flash Player. Please log on with administrative priveleges and try again.
I configured the mms.cfg file as follows:
SilentAutoUpdateEnable=1
AutoUpdateDisable=0
Any ideas why this is happening? Would like a way to have it silently auto update to latest flash version even if user is non admin, since all our users run in this capacity. Any help would be appreciated. Thanks!
So I figured out what is happening. Silent Updater creates a scheduled task, however task scheduler has been disabled on all our PCs. That's why silent updater wasnt working, and was instead just using the standard update check. You can close this case. Thanks.
This happens when updating from what version to what version?
They currently have version 11.7.700.169 and I would assume it's trying to update to the latest version which is 11.7.700.202.
Also, I just rebooted my own machine that had the same settings, except I am an admin on mine, and instead of silently updating, the updater window popped up prompting me to click the install button to update. It seems the "silent" part is not working. What am I doing wrong? Is there something else I need to do besides configuring the mms.cfg file as I noted above?
This is something the Adobe team will have to look at; silent background update should not require administrative privileges.
As my last post pointed out, it looks like it's using a regular updater instead of the silent one. Any ideas on why it's not using silent mode even though I configured the mms.cfg file as follows:
AutoUpdateDisable=0
Thanks for the feedback; good to know what caused it.
