the temporary site is "http://printtest2.businesscatalyst.com/"
this is regarding what appears to be a "catalogue" presented on the homepage of the OXO template site. I want to modify the size of the images but can't find where the code is kept.
When I'm in "design view" it looks like the content is being called by // {module_webapps,13325,a,}
and when in "code view" it looks like its called by // {module_productfeaturelist,last,2,Default,,,true}
Where can I view these pieces of code, or the module screens, and how do I modify the attributes?
Is the {module_productfeaturelist,last,2,Default,,,true}, embedded in the {module_webapps,13325,a,} and if so, where can I go to see that?
Thanks very much.
Scott.
Hi Scott, go into the admin or via FTP and change the images themsevles if you want to change product images.
If your using something with fixed dimensions etc these will be controlled by the CSS.
something is changing the file size (dimensions), the actual dimensions are smaller than what is displayed.
Can I modify the css through the BC admin interface, if so, where?
I know this is newbie stuff, but I gotta start somewhere.
Thanks.
Scott.
