Show 2 replies
1. Re: placement of the Transitions between movie clips
Harm Millaard May 21, 2013 2:25 PM (in response to steenmikkelsen2)You are missing 'handles' on the first clip. If there is insufficient material on either side of the transition, the transition is moved to the side that has sufficient material without repeating frames.
2. Re: placement of the Transitions between movie clips
Bill Hunt May 21, 2013 2:26 PM (in response to steenmikkelsen2)The problem with example 1's Clip is that it does not have any Handles - there are no Frames in front of that In Point (see the little "triangle" in its Audio, where it's still visible). This article goes into more detail on Handles with Transitions: http://forums.adobe.com/message/3727485#3727485
Adjust your In Point, to provide adequate Handles, on adjoining Clips, and then your Transitions will go between both.
Good luck,
Hunt
