I have installed the latest flash player but when I try to run programs requiring flash player i get message it needs flash player to run and go to download adobe flash player.
What is your operating system & version?
What is your web browser?
What programs do you run that require Flash Player?
DOES ANYBODY AT ADOBE EVER TRY YOUR OWN PRODUCTS ????????????
I can honestly say I don't use Internet Exploder because of the ActiveX garbage (circa 1993) that Microshaft STILL USES after EVERY OTHER BROWSER on earth dropped ActiveX in 2001.
I have exactly the same problem. new pc, running win 7, using internet explorer, have tried every solution offered under the solution tab, nothing helps. loparm500
If you are using Internet Explorer, ensure that:
You enabled Flash Player.
Disabled ActiveX Filtering.
Sunil
Don't know how to disable Active X Filtering
Also don't know how to enable Flash
It is under the the "SECURITY TAB" of "INTERNET OPTIONS", for EACH "ZONE" as in "internet", "Intranet", etc. if you select Medium or above or DEFAULT it will state to the right that ACTIVE X will NOT BE LOADED....
HAVE YOU EVER TRIED THESE RIDICULOUS ANSWERS ??????
Here it is 23 May 2013 and this problem is still HERE. I go go Hulu & try to watch something and am told to install Flash Player. The samething happens in youtube.com. I have tried, I mean tried, I have lost count, to install Flash Player and cannot get it to install. WHY??? The program states that I did a successful install and still cannot get anything done. I used the unintall that I got from Adobe. Did a registry clean. Found a sub-DIR and deleted that. I am using IE10, Windows 7 Pro, 64-bit. Restarted computer a number of times. I tried the things in the above comments with NO luck, if I did have good luck I would not be writing this, right?? What is the matter Adobe?? Why can't we call Adobe and get help??
I also keep messages to upgrade Flash player, even though I have the latest version. Getting it at home and at work, so methinks something is off with version 11.
Could be "cached" pages with an outdated Flash Player cookie. Try clearing your cache at home and work.
Have you at least tried the solutions offered earlier in this topic?
