1. Re: encodeForHTML
Adam Cameron. May 15, 2012 5:32 AM (in response to Community Help)This page should cross-ref to the page for htmlEditFormat() (http://help.adobe.com/en_US/ColdFusion/10.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7 847.html), as well as discuss the differences and merits of each; both in the context of intended usage and functionality.
2. Re: encodeForHTML
Suhas Yogin May 15, 2012 5:41 AM (in response to Adam Cameron.)Hi Adam,
Thank you for your feedback. The docs have been pushed live for CF10 http://www.adobe.com/support/coldfusion. We will make the necessary changes during the next doc refresh cycle.
Suhas Yogin
3. Re: encodeForHTML
TheCycoONE May 22, 2013 6:56 AM (in response to Community Help)When I try "EncodeForHTML('%Device%')" I end up with "Þvice%" which displays on the page as "Þvice%" Obviously this isn't what I intended. Is there a way to prevent this function from assuming the input string is encoded?
4. Re: encodeForHTML
Adam Cameron. May 22, 2013 3:33 PM (in response to TheCycoONE)I see the same. I'd raise a bug if I was you. As for a work-around, not sure, given I don't see why it's messing with your string in the first place (it already seems safe to me?)
Adam
5. Re: encodeForHTML
TheCycoONE May 23, 2013 6:58 AM (in response to Adam Cameron.)Alright, until I know more I'm sticking with the old HTMLEditFormat. In the mean time I've added Bug 3566150.
6. Re: encodeForHTML
Adam Cameron. May 23, 2013 7:05 AM (in response to TheCycoONE)Just FYI, I did some analysis here:
According to the docs for OWASP’s encodeForHtml(), this function ought to be escaping characters in these ranges: 00-08, 0B-0C, 0E-1F, and 7F-9F. However, obviously, there are no characters in those ranges in that input string.
Now I can see what’s going on: a THORN is HTML character entity 222, which is DE in hex, so if one was to treat "%DE" as a percent-encoded hex charcter, then that’d be a thorn. However percent encoding has got nothing to do with HTML (it’s to do with URIs), so that interpretation seems irrelevant to me. What I do know is that in the context of HTML, "%device%" doesn’t need encoding to be "safe", so it shouldn’t be touched by this function.
Not that this helps you, but it helps understand what's going on.
I've voted for the bug.
Adam
