I am currently running CFMX 7.0.2 (w/ a multiserver
configuration using IIS) and FDS 2.0 w/ JRun4, using Flex Builder
2.0.1 Standalone as my Flex IDE.
I am able to do remoting without a problem, and I am also
able to run the FDS CRM sample, which uses Java. But when I try to
use FDS + CF, it tells me "Could not find the Coldfusion Component
samples.contact.ContactAssembler".
I have been following the Contact Manager example, originally
posted by Tom Jordahl and later corrected by Steven Erat.
http://www.talkingtree.com/blog/index.cfm/2006/12/20/FDS-CFMX702-ContactManagerAppI am pretty sure that I have done everything correclty:
- I have all the mxml files placed in the
E:\jrun4\servers\default\samples\dataservice drectory, and have
modified the DataService destination to point to "cfcontact", not
"cfcontact-default".
- I have added the destination element from
E:\resources\config\data-management-config.xml to
E:\fds2\jrun4\servers\default\samples\WEB-INF\flex\data-management-config.xml
- I have added
<adapter-definition id="coldfusion-dao"
class="coldfusion.flex.CFDataServicesAdapter"/>
to
E:\fds2\jrun4\servers\default\samples\WEB-INF\services-config.xml
- I have unzipped the CF files into my CF root
(<CFroot>/samples/contact/) and the access file into
<CFroot>/samples/contact/db/. I also tested the CFC's to
makes sure they worked properly on their own
- I have made a datasource called FlexDataServices pointing
to the access file, and made sure it works correctly
- I have started the FDS server with no errors
But when I run the app from
http://localhost:8700/samples/dataservice/contact/contactmgr.mxml,it gives me that error: "Could not find the Coldfusion Component
So i know FDS works with Java, its CF that is giving me the
problem. Could it have something to do with the fact that I am
using IIS for CF and JRun4 for FDS (even though I dont think so
since the calls to the cfc's are not http, or so think)
Any help would be greatly appreciated...i have been trying to
get this to work for a couple of days and would love to move on.
Thank you.
