Deleted slides doesn't reduce filesize
Feb 07, 2007 Feb 07, 2007
I have a Captivate 2 project with 250 slides in it. The file size is 250Mb.
I deleted all but 10 sildes and saved the file.
The file size is still 250Mb!
I looked all over for a Pack utility, but found none.
Any suggestions?
TIA!
Getting started
407
Guest
Feb 08, 2007 Feb 08, 2007
Hello,
In the Library, you will see 6 icons along the top, the 5th one is called "select unused items". Click on that and then delete them all. What I have noticed with Captivate 2 is that even when you delete slides, it still keeps their contents in the library. Doing what I mentioned should decrease your file size.
Hope this helps
Doug
Sure, that would make sense. I forgot that Captivate 2 got a Library a-la Flash.
So, I bet that means you'd best use a repeating image (like a program desktop) from the Library instead on pasting it into the bottom layer of each slide as we did in Captivate 1, which would probably create the identical image n-times in the Library. Hmmm....
Thanks for the "whack on the side of the head!'
Help resources
