I use RH9 for HTML and compile to WebHelp. I dont know if there is a setting I am missing, but my search results are inconsistent. Ive used several variations of the search settings to see if it makes a difference and it does not. Search will find certain keywords and not others. It will not find topics that I know exist in the project. If there is a topic titled 'Change of Address' in the project and I type the word 'Address' is the search engine, I get no results. Please help!
I just tested the same string and it worked correctly.
Try creating a new layout, not a duplicate.
What browser are you viewing in? Does that make a difference?
The situation still remains unresolved and got progressively worse. I had to disable the search tab. Have you ever heard of such a thing? Adobe has been unable to recreate the scenario, but in online sessions can clearly see the results that I get are different than what they get, which makes me think its not RoboHelp causing the problem, but rather something interfering with my output. Every project that I have (about 13 or so) cannot use the RH search feature. Results come back as "Null". It's got to be something in the company firewall or something that is preventing this feature from working, but unless I can pinpoint the issue, I cant have our internal IT folks work on resolving it. I am browsing in IE8 and cannot change that to see if it functions in a later version or Chrome. It previously worked in IE8 though. If anyone has had a similar situation, please let me know. Having projects with no search capability is less than ideal.
Can you share a "deficient" project with us? Maybe we can see the same results outside of your environment?
Did they ask you to try one of the sample projects?
I cant share a project with anyone outside of Adobe unfortunately. These projects are Corporate Record for my company. I did try a sample project (no one had suggested that yet - so thank you Peter!) and search fails there as well. Which definitely leads me to believe there is something in my company's system that is interfering with the initialization of the database. I have little confidence that anyone in IT will know how to resolve this, but it gives me a starting point to request testing on machines that are not altered with our security, etc.
Can you take the files of the sample project output outside your corporate IT environment (like home) to test them? If they work there, then it's definitely your corporate environment that's the problem.
There's more to try yet.
Has it ever worked?
Was Rh installed with local admin rights?
Did Adobe have you uninstalll and reinstall?
Where are generating the help to? Is it a local drive?
Yes it worked for years. RH has always been installed with local Admin rights on my PC. i generate to webhelp and publish to a server for our local intranet site. I am one of several Admins and we are all now experiencing the same issues in all projects. Adobe took copies of our projects and Search works fine for them. I fear that the issue coincided with an upgrade to Win7 back in April 2012. I was not part of the testing of RH9 and Win7 so Im unsure if anyone specifically tested search. It could also be the result of one of our many many security patch updates over the last year. I will begin testing on a clean machine to try to pinpoint the cause. Thanks for all your help and ideas!
Rh9 was tested during the beta on Windows 7 and I still use it regularly. Search is fine.
You didn't confirm the generated (rather than published) is being generated to a local folder rather than the network. Are you testing the search in both generated and published help>
Also you didn't confirm whether or not an uninstall and reinstall had been tried.
My company likes to customize everything..including Win7. Our local desktops run through a server since we received Win7. So, I'm sure it's not an out-of-the-box issue with Win7 and RH, but rather something we have customized that is interfering. I generate locally to my desktop and then move the generated files to a server. I have tried it on my PC and also on the server and it doesn't work. I have not tried an uninstall/reinstall because there are 6 of us all generating content and it doesn't work for any of us. I don't have Admin rights so I can't do it without IT support. They remove our access after they install RH with local Admin rights.
Might be worth getting IT to give one of you admin rights while they hover over. Generate while you have those rights and see if that makes a difference.
Rh used to require admin rights but now it is only required for installation. However, with these problems, it is worth a try.
Fixed now?
Unfortunately, IT just doesn't move that fast. Im still waiting for someone to approve my request for testing. 😞
IT just installed Google ChromeFrame BHO and the search stopped working. Still using IE to open the help (created in RH9). coworker stopped working first. mine was still working then I saw the install program fire up (they pushed it out) and as soon as the install finished, I could no longer do search. Is there something I can do other than uninstall this Google chrome piece for a couple hundred users of my help?
You’ll need to identify what exactly is making your search stop working - what help flavour are you producing? What did IT roll out?
They loaded a plug in - ChromeFrame BHO and we are still using IE. I’m creating Webhelp using RH9
IT is going to uninstall the plug in since the Chrome website apparently just announced today that they are discontinuing ChromeFrame dev and pulling support for it in January.
So never mind
