0 Replies Latest reply: May 28, 2013 7:12 AM by slornitzo RSS
    How can I remove the pagination controls in <cfgrid> but leave the delete button
    slornitzo Community Member
      I have a <cfgrid> (coldfusion 8) and I am trying to remove the pagination controls (There will only ever be 1 page) but leave the delete button.
      Or alternatively,  remove the footer (which I figured out how to do) and add the delete button to each row.
      (And yes I need the grid)
      I've tried overriding the CSS  both with  a <style> tag on the page and Ive also tried using a function calleled on load to change the disply to none  (which works in firebug when I manually do it)
      Neither seem to work. I;ve searched all over and tried various things, but nothing seems to accomplish waht I need. Any help would be most appreciated.
      ****Code***********
      <cfajaxproxy cfc="AddSelectedOptions" jsclassname="AddSelectedOptions">
      <cfajaxproxy
          cfc = "AddSelectedOptions"
          jsclassname = "AddSelectedOptions">
      <html>
          <head>
          <cfajaximport tags="cfgrid"/>
          <script type="text/javascript">
      var cfc = new AddSelectedOptions();
      //cfc.setErrorHandler(showError);
      cfc.setCallbackHandler(handleResult);
          function showWin(){
              alert('Button 1 works!!! :-)');
          function showWin2(){
              alert('Button 2 works!!! :-)');
      function delSelected()
                  var selectedRecord = grid.getSelections();
                  var delID = selectedRecord[0].data.ID;
                  if(confirm('Delete User : ' + selectedRecord[0].data.FIRSTNAME))
                      cfc.delSelectedCats(delID);
        function AddSelected(SessionId)
      var Cat = document.getElementById("SelCategory");
      var CatSelIndex =Cat.selectedIndex;
      var CatId = Cat.options[CatSelIndex].value;
      var SubCat = document.getElementById("SelSubCat");
      var SubCatSelIndex =SubCat.selectedIndex;
      var SubCatId = SubCat.options[SubCatSelIndex].value
        cfc.AddSelectedOptions(CatId,SubCatId ,SessionId);
      function handleResult(res)
      ColdFusion.Grid.refresh('SelectedCategories',false);
      var gridRender = function()
              grid = ColdFusion.Grid.getGridObject('SelectedCategories');   //Get grid object
              //overwrite existing grid footer with new div, Ext.id() will assign unique id to footer
              var bbar = Ext.DomHelper.overwrite(grid.bbar,{tag:'div',id:Ext.id()},true);
              //Create new PaginToolbar and render it to bbar (grid footer)
              gbbar = new Ext.PagingToolbar({
                 renderTo:bbar,
                 store: grid.store,
                          pageSize: 10,
                          displayInfo: true,
                          displayMsg: '<b>Showing {0} - {1} out of {2}</b>',
                          emptyMsg: "<b>No Record</b>"
      </script>
      <style >
      #ext-gen67{Display:None;visibility:hidden;};
      #ext-gen59{Display:None;visibility:hidden;};
      #ext-gen75{Display:None;visibility:hidden;};
      #ext-gen76{Display:None;visibility:hidden;};
      #ext-gen79{Display:None;visibility:hidden;};
      </style>
      </head>
      <body>
      <cfform action="" method="post">
      Select Category and Subcategory
      <table>
      <tr>
      <th>Category</th><td colspan="2">
      <cfselect name="SelCategory"
      bind="cfc:AddIncident.Categories()"
      bindonload="true"
      id="SelCategory"
      class="field_150"
      style="width:150px;"/>
      </td>
      <th>SubCategory</th>
      <td colspan="2">
      <cfselect name="SelSubCat"
      bind="cfc:AddIncident.SubCategories({SelCategory})"
      bindonload="true"
      class="field_150"
      id="SelSubCat"
      onChange="AddSelected('999');"/>
      </td>
      </tr>
      </table>
      <h4>Click on a row and select delete to remove.. will figure out how to add a delete button to each row</h4>
      <cfgrid
      name = "SelectedCategories"
      format="html"
      bindOnLoad="yes"
      bind="cfc:SelectedOptions.getSlectedGrid({cfgridpage},{cfgridpagesize},{cfgridsortcolumn}, {cfgridsortdirection},'999')"
      preservePageOnSort="true"
      selectmode="edit"
      delete="yes"
      DeleteButton="Delete"
      selectOnLoad="no"
      font="Verdana"
      fontsize="11"
      label="True"
      stripeRows="true"
      stripeRowColor="##D9CCFF"
      selectColor="##994FE6"
      pagesize="5"
      onChange="cfc:AddSelectedOptions.delSelectedCats({cfgridaction},{cfgridrow},{cfgridchanged })"
      <cfgridcolumn name="PK_SELECTIONID" display="no" >
      <cfgridcolumn name="SELECTION1DESC" display="yes" header="Category" mask="EEE DD-MMM-YY H:NN A">
      <cfgridcolumn name="SELECTION2DESC"  display="yes" header="SubCategory">
      <cfgridcolumn name="Delete"  display="yes" header="Delete">
      </cfgrid>
      </cfform>
      <cfset ajaxOnLoad("init")>
