Built Apache using openssl 1.0.1e (updated LD_LIBRARY_PATH to reflect the correct openssl libs) and pcre. Configure for build was:
configure --enable-ssl=shared --with-ssl=/usr/local/ssl --enable-so --with-included-apr --with-pcre --with-perl
Also downloaded and built the connector from http://helpx.adobe.com/coldfusion/kb/rhel-connector-configuration.html after the vanilla CF install didn't work. I get the following when I try to start up CF:
[root@web01 logs]# /etc/rc.d/init.d/coldfusion_10 start
Starting ColdFusion 10 server instance named cfusion ...
The ColdFusion 10 server instance named cfusion is starting up and will be available shortly.
nohup: appending output to `nohup.out'
Running the ColdFusion 10 connector wizard
Configuring the web server connector (Launched on the first run of the ColdFusion 10 start script)
Running /usr/local/apache2/conf connector wizard...
There was an error while running the connector wizard
Connector installation was not successful
ColdFusion 10 server instance named cfusion has been started.
ColdFusion 10 will write logs to /opt/coldfusion10/cfusion/logs/coldfusion-out.log
The wsconfig.log contains the following:
[root@web01 wsconfig]# cat wsconfig.log
# Created by ColdFusion on 05/28 15:15:23
05/28 15:15:23 info Tomcat Connector
05/28 15:15:23 debug command line: -ws Apache -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -dir /usr/local/apache2/conf -v
05/28 15:15:23 info Red Hat Enterprise Linux Server release 6.4 (Santiago)
05/28 15:15:23 debug Using Apache binary /usr/local/apache2/bin/httpd
05/28 15:15:23 info Server's Module Magic Number: 20051115:31. Supported major magic numbers on this platform are 20020628 and 20020903.
05/28 15:15:23 info Attempting to build connector from sources
05/28 15:15:23 info Server version: Apache/2.2.24 (Unix)
05/28 15:15:23 debug Using Apache control script /usr/local/apache2/bin/apachectl
05/28 15:15:23 debug Parsing Apache configuration file /usr/local/apache2/conf/httpd.conf
05/28 15:15:23 debug Exec'ing chmod 777 /opt/coldfusion10/config/wsconfig/1
05/28 15:15:23 debug Set permission to 777 on /opt/coldfusion10/config/wsconfig/1
05/28 15:15:23 debug Exec'ing chmod +x /opt/coldfusion10/config/wsconfig/1/mod_jk.so
05/28 15:15:23 debug Set permission to execute on /opt/coldfusion10/config/wsconfig/1/mod_jk.so
05/28 15:15:23 debug Created file /opt/coldfusion10/config/wsconfig/1/mod_jk.so
05/28 15:15:23 debug Wrote file /usr/local/apache2/conf/httpd.conf
05/28 15:15:23 debug Added ColdFusion configuration to Apache configuration file /usr/local/apache2/conf/httpd.conf
05/28 15:15:23 debug Created file /opt/coldfusion10/config/wsconfig/1/README.txt
05/28 15:15:23 debug Wrote file /opt/coldfusion10/config/wsconfig/wsconfig.properties
05/28 15:15:23 debug Exec'ing /usr/local/apache2/bin/apachectl restart
05/28 15:15:23 error Error running "/usr/local/apache2/bin/apachectl restart": exit code was 1
05/28 15:15:23 error Error restarting Apache server. The web server must be restarted to complete this operation.
com.adobe.coldfusion.connector.connectorinstaller.WebServerException: Error restarting Apache server. The web server must be restarted to complete this operation.
at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.restartWS(ApacheInstaller.java:480)
at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(ApacheInstaller.java:269)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.installConnector(ConnectorInstaller.java:340)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.doIt(ConnectorInstaller.java:284)
at com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstaller.main(ConnectorInstaller.java:741)
05/28 15:16:37 info Tomcat Connector
05/28 15:16:37 debug command line: -ws Apache -dir /usr/local/apache2/conf -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -cfide /opt/coldfusion10/cfusion/wwwroot/CFIDE -v
05/28 15:16:37 error This web server is already configured for ColdFusion.
com.adobe.coldfusion.connector.connectorinstaller.ConnectorInstallerException: This web server is already configured for ColdFusion.
at com.adobe.coldfusion.connector.connectorinstaller.ApacheInstaller.installConnector(ApacheInstaller.java:187)
I've searched and tried just about everything I could find relating to the error info.
RHEL 6.4 is not the supported version of RHEL, Supported version are 5.6 and 6.1. We published an article you can try if that helps.
However if that doesn't work please try this in Supported environment.
Priyank
Priyank,
Thanks for the info. I had already tried that article building the connector already, so it does not help the issue. Hadn't located the support matrix re OS levels. The rest of my RHEL installs are 6.3 or higher, so I was hoping to go with the same. I'll try rebuilding with 6.1 and see if that helps. I've seen some references to using Apache 2.4. Is that officially supported with CF10? I need to get something stable built with whatever versions are known to work well.
Sue
Do you have any errors or interesting messages in the CF or Apache log
files ? Is the mod_jk module loaded into apache ? (Here's a typical config
snippet for Apache:
http://help.adobe.com/en_US/ColdFusion/10.0/Admin/WSc3ff6d0ea77859461172e0811cbf363a5d-7ffb.html
Mack
Mack,
From Priyank's post, I now suspect the issue lies with RHEL 6.4. I've looked at the link you included, plus the custom connector build one, and it still won't load up. I'm going to rebuild the server with RHEL 6.1. I like to be using supported configurations.
Sue
Sue,
Did you ever discover if the issue was with RHEL 6.4? Did 6.1 work fine for you? IT is starting the process to upgrade our environment and their standard is 6.4.
Greg
Greg,
Unfortunately, I was only able to get it to work on RHEL 6.1 with Apache 2.2.24. The project got canned, so I never pursued it further.
Sue
