Has ant one experienced cftextarea not displaying tool bar in ie 10. Thanks in advance.
I have the same problem but no answer. There is an solution with ajaxOnLoad(). Maybe someone can explane this solution?
Here is the solution.
You have to make the changes in de FCKEditor.js
http://http://kartiksehgal.wordpress.com/2012/11/16/fckeditor-bug-fix-for-ie10/
Link you provide in reply is broken. also what kind of chagnes I've to make in FCKEditor.
Broken link :-
http://http://kartiksehgal.wordpress.com/2012/11/16/fckeditor-bug-fix- for-ie10/
Thanks in advance.
IE 10 is the first browser where the major version number (before the dot) is in double digits.
Most scripts, including the one written for FCKEditor at the time had a browser detection regex pattern that expected only a single digit before the dot (see below)
var sBrowserVersion = navigator.appVersion.match(/MSIE (.\..)/)[1] ;
The following change will thankfully remediate the situation immediately.
var sBrowserVersion = navigator.appVersion.match(/MSIE ([\d.]+)/)[1] ;
Thanks.
where do i have to add this line. var sBrowserVersion = navigator.appVersion.match(/MSIE ([\d.]+)/)[1] ;
/CFIDE/scripts/ajax/FCKeditor/fckconfig.js
In our configuration it was actually that line in the fckeditor.js file, not fckconfig.js (same directory).
That change did allow the editor to show up in IE10, but like some other users have reported - the text field still doesn't accept actual input. Has anyone run into that or know of a solution?
Thanks.
I have the same Issue, but with IE11 now.
I did the change :
and the editor toolbar does not come up.
I am very ennoyed with this. I am surprised that no many people ask solution for this.
Does that mean that cftextarea is not used by CF users ?
And I am spending a lot of time with so basic things wich should be responded by adobe
as soon as possible.
Thanks for any urgent help.
Pierre.
