1. Re: advantages of PPRO 5.5 over 5.03 please
JSS1138 May 21, 2013 4:25 PM (in response to tfi productions 44)CS6 is a significant advance over 5.5. You should at least download the trial and see if you experience any issues. Not all AVCHD media is affected.
2. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 21, 2013 4:34 PM (in response to JSS1138)hello Jim
i agree that not all avchd is affected with the spanned clips issue
but the thread that states that avchd footage lags and isn't responsive even on a beast of a system
has me worried...
http://forums.adobe.com/thread/1216612?tstart=0
i am reluctant to install trial cs6 to check because my 5.03 is so stable i don't want to risk it
cheers, j
3. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 21, 2013 4:48 PM (in response to tfi productions 44)As a user who skipped CS5.5, I am inclined to recommend the same.
As I recall, the biggest wow feature for 5.5 was Warp Stabilizer.
The most important core changes to Premiere came with CS6.
If you do not plan to subscribe to CC, and you still want
to update your CS5.0.3, I think you should move to CS6.
There were many advances from CS5 to CS6 that make it worthwhile.
And, unless your primary media source is affected, you shouldn't
be too afraid of the AVCHD / spanned clip bug in CS6.
If you happen across media CS6 can't handle well, just keep
CS5 installed for flipping any problem media before editing in CS6.
I have CS5.0.3 and CS6.0.3 installed together without conflict.
My 2¢
Download the trials and see what you think:
Adobe CS5.5 Trial Downloads: Direct Links
http://prodesigntools.com/adobe-cs5-5-direct-download-links.html
Adobe CS6 Trial Downloads: Direct Links
http://prodesigntools.com/adobe-cs6-direct-download-links.html
Be sure to read "Note: Very Important Instructions".
4. Re: advantages of PPRO 5.5 over 5.03 please
JSS1138 May 21, 2013 4:44 PM (in response to tfi productions 44)but the thread that states that avchd footage lags and isn't responsive even on a beast of a system has me worried...
It also has me skeptical. I do experience a slight lag with AVC media compared to MPEG2 or DV. But nothing that makes the software unusable, and in truth, nothing that I wouldn't expect from such computationally difficult compression. That's why I suggested giving it a try. For me the lag is very minimal (1/4 to 1/2 second maybe on my i7 2500K) and so far only affects GOP footage. I'd certainly not want to give up all the benefits of CS6 on that account.
Spanned clips are a different issue, and if your media is affected then CS6 really does become largely unusable without transcoding that footage. But again, test first. Not all spanned media is affected. (Mine isn't.)
CS6 will not interfere with 5.0.3. The two can happily coexist on the same system and in fact many people have multiple versions installed.
5. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 22, 2013 8:12 AM (in response to JSS1138)hello,
i do appreciate your helping me out
i guess it is a matter of quantifying the 'lag' of avchd (independent of the spanned avchd issue)
here is a reponse about it (the thread is linked afterwards)
If you don't "HAVE" to have CS6 right now and are slammed with projects, then I would wait and see if they fix it in the next release. I use a quite a bit of AVCHD and it is much less responsive in CS6 than it was in CS5. We have had several updates and it is still an issue... hoping Adobe makes it right.
@Jim: could you briefly explain GOP footage...i use canon hfs20 vixia avchd 60i camera that records as mts files. i plan on sticking with them until i make a move to a 4k camera in the future.
I'm no software engineer (any more), but I'm curious what makes you think it's a bug and not just unrealistic expectations of editors wanting DV performance out of the very difficult to edit AVCHD media? I mean, is there something going on at the software or driver level that you're been able to test?
I ask because I see similar lags when I work with 12 GOP patches on my GH2, but with I-frame patches the performance is significantly better, almost DV-like. Same codec, different encoding scheme, so I just attributed the performance lag to the nature of the media. I'd be interested to know if you're seeing things 'under the hood' (as it were) that lead you to a different conclusion.
2) if i do install the trial cs6 does it install into it's completely own folder?
also, besides the main PPRO folder i'm concerned with all the other folders PPRO installs
in terms of messing up my cs5.03 installation
3)by installiing the PPRO 6.03 update/trial will i 'see' the bugs if my camera/footage is affected?
i would hate for everything to be groovy with 'the trial' only to buy the production premium
and have it be 'whack'
thank you for taking time to further explain, j
6. Re: advantages of PPRO 5.5 over 5.03 please
JSS1138 May 22, 2013 8:17 AM (in response to tfi productions 44)CS6 will install everything to a different folder. Nothing will be shared with older versions. For example, any plug-ins you have for CS5 will need to be reinstalled for CS6 if you want to use them there.
The trial works just the same as the paid version, you won't see any performance difference between them.
7. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 22, 2013 8:37 AM (in response to tfi productions 44)if i do install the trial cs6 does it install into it's completely own folder?
CS6 installation goes into its own folder structure,
and does not conflict at all with CS5.0.3.
As I mentioned in my post, I have both installed without conflict.
If you do a LONG roll (20-25 minutes) that requires clip spanning
at 4GB, then you should see the bug if your camera is affected.
8. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 22, 2013 8:37 AM (in response to JSS1138)...any plug-ins you have for CS5 will need to be reinstalled for CS6 if you want to use them there.
For plugins that do not require running an installation program,
you can make 'shortcuts' instead of copying each plugin
for use in both CS5 and CS6.
Create shortcuts for all files/folders from:
C:\Program Files\Adobe\Common\Plug-ins\CS5\MediaCore
Add them to:
C:\Program Files\Adobe\Common\Plug-ins\CS6\MediaCore
9. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 24, 2013 11:24 AM (in response to joe bloe premiere)hello,
i am going to give cs6 PPRO trial a go
(sorry for the simple question) if i download the entire production premium trial suite cs6
1.)does it install completely separately from cs5.03?
does it uninstall easily/completely?
2.)is there a cs6 cleanscript tool?
thanks in advance, j
can someone point to a link with the trial restrictions of the production premium cs6 trial
and/or the apps included in the cs6 production premium suite please
i have open the webpage of the cs6 direct download links provided in this thread stated above....
10. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 24, 2013 11:47 AM (in response to tfi productions 44)1.)does it install completely separately from cs5.03?
Re-read posts 3, 4, 6 and 7.
They all answer this question directly.
Yes.
Dunno... probably.
I have never needed one.
Adobe Premiere Pro Help /
Trial version limitations | Adobe Premiere Pro | CS5, CS5.5, CS6
http://helpx.adobe.com/premiere-pro/kb/trial-version-limitations-premiere-pro.html
can someone point to a link...
...the apps included in the cs6 production premium suite please
http://webobjects.cdw.com/webobjects/media/pdf/adobe/CS6-Production-Premium-Datasheet.pdf
11. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 24, 2013 12:15 PM (in response to joe bloe premiere)hello, @ joe bloe premiere
you are very kind, thank you...
j
12. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 24, 2013 12:57 PM (in response to tfi productions 44)you are very kind...
You shouldn't jump to conclusions.
13. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 24, 2013 1:07 PM (in response to joe bloe premiere)hello,
i'm downloading the cs6 ppro trial from the direct link provided above
the 1st file is a small .exe file -- is this correct?
the 2nd file is the 1.1 gb file
i will download the 'extra content'
my question: can i install the 6.03 PPRO cs6 update to a trial download?
thanks, j
14. Re: advantages of PPRO 5.5 over 5.03 please
joe bloe premiere May 24, 2013 1:19 PM (in response to tfi productions 44)the 1st file is a small .exe file -- is this correct?
From the instructions on the download page linked above:
"For Windows, each program consists of
up to two files, an .exe and a 7-Zip file (.7z).
The .exe file will only work when the .7z file is also
fully downloaded and resides in the same location.
For the Mac, it’s just a single .dmg file for each program."
I have never tried, but would assume so.
After installing, run Adobe Application Manager / updates first and see.
15. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 27, 2013 9:10 PM (in response to joe bloe premiere)hello,
i installed the cs6 trial of production premium: all went well
can anyone state what the 'functional content' is for Encore please? (1.3GB)
and to where did it install?
can anyone state what the 'functional content' is for PPRO please? (211MB)
( i had everything install to C:PROGRAMS:ADOBE:CS6)
i am going to try to apply the most recent updates and will post back...
thanks again for all your help...
j
16. Re: advantages of PPRO 5.5 over 5.03 please
tfi productions 44 May 28, 2013 8:42 PM (in response to tfi productions 44)hello,
all the current cs6 updates installed 'successfully'
except ILLUSTRATOR 16.03...any ideas why not?
also, i guess MOCHA FOR AE is gone...
i have found my 'spanned clip footage' to try in PPRO cs6
it is one continuous take of a graduation ceremony
that filled the built in hdd of a canon vixia hfs20 avchd camera
we'll see how it goes, cheers, j
