Show 4 replies
1. Re: Problems connecting device
Mark_RauschMay 29, 2013 11:01 AM (in response to xZakx)
Some things to check and some info:
- Using the host name to connect your phone to your computer won't work unless your network has it's own DNS that resolves that host name. This is a pretty rare situation, so I'd just stick with using the IP address in the manual connection field.
- Make sure you're not on VPN on either your computer or your phone.
- Disable any software firewalls on your computer. Once you get a connection you can re-enable the firewall and start fiddling with settings to allow Edge Inspect through, but disabling it is simplest to start with.
- Make sure nothing is blocking or already using port 7682.
- Are both your computer and your iPhone on the same network? Is it possible they're on different subnets and if so, is communication on port 7682 open across those subnets?
- What OS version is your computer running? What version of Chrome are you running on your computer?
Mark
2. Re: Problems connecting device
xZakx May 30, 2013 10:07 AM (in response to Mark_Rausch)Here's my comments:
I tried host name and IP address. Neither works. - Make sure you're not on VPN on either your computer or your phone.
Not on a VPN. - Disable any software firewalls on your computer. Once you get a connection you can re-enable the firewall and start fiddling with settings to allow Edge Inspect through, but disabling it is simplest to start with.
We do have software firewalls on our machines. Checking with admins to see if this can be disabled locally. - Make sure nothing is blocking or already using port 7682.
Admins are checking on this. - Are both your computer and your iPhone on the same network? Is it possible they're on different subnets and if so, is communication on port 7682 open across those subnets?
Admins say no, they're not on the same network...they are on different subnets. They're checking communication on port 7682 now. - What OS version is your computer running? What version of Chrome are you running on your computer?
Windows 7 w/ all updates applied / Chrome Version 27.0.1
I'll post my findings once I have them...thanks.
3. Re: Problems connecting device
xZakx Jun 4, 2013 8:56 AM (in response to xZakx)We got it going. The problem was a combination of 4 and 5. Thanks.
4. Re: Problems connecting device
Mark_RauschJun 4, 2013 10:12 AM (in response to xZakx)
Glad to hear it's working now. Thanks for letting us know.
