1. Re: CPU Fan Error.
Harm Millaard May 29, 2013 2:44 AM (in response to El_Plates)First thing to do is check that the CPU fan starts up when you turn on the power of your PC. If that is the case, go into the BIOS and reduce the warning RPM level for the CPU fan. It may be set at 1200 RPM, but the actual RPM may be only 600 RPM. For safety, check your CPU temperature when idle, it should not be over 45° C.
2. Re: CPU Fan Error.
oliewdj May 29, 2013 2:53 AM (in response to El_Plates)Like Harm said, my p8p67 will do this if i set my potentiometer too low on the fan control on boot - the rpm isnt high enough for the mobo to say its working but i can reduce rpm it once windows is booted when im not doing much with the pc (for quietness), so i would check its running at all and what rpm in the bios.
cheers
Oli
3. Re: CPU Fan Error.
El_Plates May 29, 2013 4:51 PM (in response to Harm Millaard)Ok. I'm checking those things now.
Temperatures at idle are 34 - 41, depending on the core (the sixth one is always highest).
Today was atypical, in that the message didn't appear when starting the PC.
I'll try observerving the fans for movement, again tomorrow.
Right now both CPU fans are spinning.
I'll check the BIOS now, and see what the fan RPM warning level is currently set at.
