We upgraded from RH8 to RH10 and some of the topics are not formatted. (1484 topics) There is alot of extra spacing inbetween bullets and alpha numbering.
For example:
<ol style="list-style: decimal;">
<li style="list-style: none; display: inline;"><ol start="1" style="list-style: decimal;">
<li class="p" style="list-style: lower-alpha;"><p style="margin-left: 0px;"><span
style="margin-left: 48px;">Enter a <span style="font-weight: bold;">Business
Name</span>, if applicable. This field is not required if you
are not establishing a business account and when you provide a
first and last name. The value entered is displayed on the customer's
invoice and is limited to 30 alphanumeric characters.</span></p></li>
</ol></li>
What do I need to eliminate in the HTML code? And is there a way to programatically remove all the extra spaces?
Thank-you,
Michelle
I think your problem is because you are generating to a network drive. You should generate to a local drive and publish to a network drive.
I changed your start page in the project you sent to index.htm as I don't like having a start page with the same name as a topic and generated to a local drive.
Works fine. Correct formatting.
Also I would avoid spaces in a CSS file name.
are you seeing this in the RH topic or the produced help?
I am seeing this in the RH Topic after I click the eyeglasses icon to view as generated.
that's not exactly accurate - try generating some help & having a look at it
We generated RH10 and the formatting is different along with the font style, appears to be Times New Roman instead of Verdana across the board. Heading 1 and Heading 2 are black instead of royal blue. The popups are are not grabbing the skin and have a smaller font.
We have a custom 'infostyle' style that is not displaying the box with the checkmark in the center:
p.Infostyle {
vertical-align: Super;
text-indent: ;
background-repeat: No-Repeat;
padding-left: 40px;
background-position: Left Top;
list-style: ;
margin-top: 15pt;
margin-bottom: 12pt;
letter-spacing: normal;
font-style: normal;
margin-left: 57px;
line-height: Normal;
padding-right: 1px;
padding-top: 4px;
padding-bottom: 5px;
text-align: left;
font-weight: normal;
background-image: url(checkbox.bmp);
Note: We are using RoboSource to refresh our hard drives. After the upgrade an error is displaying after we refresh -- something about the rhscreens.apj. Clicked 'OK' twice to get into the application.
In other words, my style sheet is fine until I generate the help file and then the style sheet changes.
Check that you have not selected a stylesheet to in the single source layout that is overriding the topic CSS.
Make sure the Apply to all Topics check box is not selected.
The generator is still changing my .CSS even after unchecking the 'apply to all topics' checkbox. Do I need to get rid of the Master Page .htt? Each topic has a Master Page and the .CSS applied to it.
Same issue:
The formatting is different along with the font style, appears to be Times New Roman instead of Verdana across the board. Heading 1 and Heading 2 are black instead of royal blue. The popups are are not grabbing the skin and have a smaller font.
I just created a new project and imported my .css file and generated the webhelp file using RH10. The same issues - the generated help file is not viewing my .css file.
I have IE8 brower and Windows 7 operating system.
See the Contact page on my site and send me the new project. I assume you just created one or two test topics.
Peter,
I was able to make the .CSS behave in my test project that I sent you earlier today. I tried several different settings, etc.. but this worked: I right-clicked the .css in the Project Manager and created a new Baggage File, generated and it worked! Ok....now I have to try this in the mega huge 'real' project.
I'll let you know how it works out.
Thank-you,
Michelle
Success! I right-clicked on the .CSS file and selected New>Baggage File... and after generating the styles were working. I don't know where those other styles were coming from but the baggage file fixed this issue.
