I am unable to edit any interactions in Adobe Presenter. This appears to be a horrible and unuser friendly feature, I just can't believe it is that bad. Something must be wrong. I can't delete options at all. I can't control text in tab area - in process tab interaction. I can't type, or add pictures that aren't stretched. It seems to be slow and non responsive most of the time, and sometimes. I get an Allow/Deny box for Flash, but it doesn't even let me click either. It just hangs. I don't have this problem with any other software product I use including Adobe Captivate. I am really dissappointed in this product, I thought it was supposed to be easy, I cancode this faster in a variety of other tools. Please help - time is of the essence!
Hi
Can you please let me know what you meant by "can't delete options"?
Are seeing that the contents in the published output appear to be stretched?
When exactly do you get the Allow/Deny box?
these information would help us solve the issue
it would also be helpful if you can send me the presentation and also the images that you see are being stretched
Mahesh
The presentation is huge. I can't send. However, even on a single slide presentation when I add an interaction it does not work.
Delete - for exampe if I try to use a process tab interaction, it starts with 4 tabs, but I only want 3 tabs. How can I delete a tab.
The label on the tab is too small - I need to put 3 words on it, can't I shrink text size or use more of tab.
When I enter a graphic using the icon, it is not moveable and is not size right.
I don't see how I can add text, etc to the interactions. It seems to freeze, the instructions for how to edit interactions is very poor, so though very technical, I don't understand how to edit/add my own content to an interaction. Aren't there more robust instructions with maybe a video demonstration on how to use, edit/customize interactions?
Is there an option for allowing Flash that I should be setting on my computer? That seems to be a potential problem, like enabling java?
Thanks in advance for your help
Susan
Ride on......
Hi Susan
Am sharing with you a small demo file via which you can see how you can work on interactions
Can you please email me at mkalyanp@adobe.com so that I can share the demo with you
If you want more demos please let me know.
Mahesh
Please find the interactions demo at
https://workspaces.acrobat.com/?d=fLFtFEvwyNHCL3ABu6NIHA
Mahesh Nayak
I downloaded the demo but it doesn't work. Gives a message, "Project has expired". Are there any other resources for Presenter Interactions.
Hi
Please find the updated demo here https://workspaces.acrobat.com/?d=LTA7HMyVdsGKvpzvrMfV9g
Mahesh Nayak
