Toc will not synchronise in large files
Participant ,
Oct 20, 2006 Oct 20, 2006
Using Webhelp, the TOC fails to synchronise on the web when there are too many topics. It displays the correct page but the TOC does not update.
If i delete topics out it works. If the file is to big, it says "Loading files - click to cancel" when a book is opened towards the end of the file. I presume in this instance that all the files are not initially loaded in for some reason so the TOC cannot synronise?
Are there limits in Webhelp or could this be something to do with the browser?
878
Welcome to the forum.
I think what you are describing is what is covered by Snippet 49 on my site.
Valorous Hero ,
Hi gc31 and I too welcome you to our community
If you could try the following and report back as to whether this works, I'd appreciate it.
When generating WebHelp by double-clicking the layout, if you click the Next > button twice, you should see the Navigation Pane format and Optimize Speed options. I believe that if you change from Web Site (the default setting) to Local PC, the synchronization begins working, as all the navigation is stored in a single file and not hundreds or even thousands of smaller files.
Please give that a try and report back if it helps. I'm trying to confirm if it is a solution for this issue.
Cheers... Rick :)
Participant ,
yes - that makes sense because with large projects it doesnt seem to be able to load in all the required files - i will give this a go on monday and let you know. Cheers
Participant ,
Thanks. Yes - it seems to be a problem similar to this. I will give it a go.
Participant ,
Oct 23, 2006 Oct 23, 2006
Rick,
You suggestion of using the Local PC option has fixed the TOC problem for large files - thanks alot.
One final question - i am confused as to why you would use the "Web Site (the default setting)" option? - what are the benefits of using this?
Peter - i didn't get to try your method as the suggestion by Rick worked for me. Thanks for directing me to your website though - it has been most useful.
My solution was for a different problem so if Rick's solution worked, then I had inferred the wrong problem from your post.
You might also like to look at Rick's site and download some of his files. They contain a LOT of information.
http://www.robowizard.com
Guest
Oct 24, 2006 Oct 24, 2006
Peter,
I used snippet #49 to (partially) fix my toc problem. Now if you navigate topics in a long list and click the topic, the topic is "anchored" and highlighted.
The problem is still the same though (topic highlighted, but not shown) if I click a link in a topic. The new topic is still highlighted, but the toc does not jump to the file and show it anchored.
Do you (or the person who found this fix) have any suggestions?
Brian
Guest
Oct 30, 2006 Oct 30, 2006
Hi Rick,
I had no idea this was due to the enormity of my help system, but this fixed my problem with the TOC not syncing. Thanks for that. I was really sweating bullets!
Anything I should keep an eye out for as a result of changing this setting? My users should be on pretty fast internet connection, so if that's all it is, I think we'll be okay.
H
Feb 09, 2007 Feb 09, 2007
I too am working with WebHelp, RH5, and Context-sensitive help. I cannot get the TOC to sync for some of the calls. I tried using the Local PC option, but it still does not work. My project is not large- it is under 400 topics.
Any other ideas?
Guest
I think 400 topics is big for what we're talking about here. My only solution was to remove links from any books in the TOC. Not ideal at all. Not sure if this is fixed in the new version of RH. I would certainly hope so.
I am not sure Donna is talking about the same issue that started this thread. That was about when a topic is in a long list of topics in a TOC and whilst the item is highlighted, it does not show on the screen, the user has to scroll down to find that it is highlighted. That was not a RH issue and the problem does not arise with IE7.
I think Donna is talking about when a topic is called as CSH and it just does not synchronise at all. If that is correct, see Step 8 of my topic about merged webhelp, perhaps that will help.
If this doesn't help Donna , then please clarify for us.
I apologize; I posted this to the wrong thread. You are correct. The issue I am referring to is a TOC that will not display the page that is accessed through context sensitive help. The CSH works fine, but the TOC remains closed. Oddly enough about 1/3 of the project works correctly. I tried changing the option to Intranet as opposed to Internet on the project properties- still no luck.
So have you look at Step 8?
I edited the whthost.js file. I will need to wait until the developer moves the file into the test environment to see if it works with the CSH.
I will let you know.
THANKS!
Feb 14, 2007 Feb 14, 2007
Modifying the whthost.js. worked fine. Thanks!
RoboHelp Documentation
Download Adobe RoboHelp
