1. Re: Cannot "Enable" Flash Player
pwillener May 31, 2013 9:59 PM (in response to hillahant)hillahant wrote:
Manage Add-ons for Shockwave Flash Object, both "Enable" & "Disable" buttons are greyed out.
I see only one such button on my IE10.
Can you right-click on Shockwave Flash Object and select Enable (or Disable)?
2. Re: Cannot "Enable" Flash Player
hillahant Jun 1, 2013 8:18 AM (in response to pwillener)Hi, Pat,
Here are more details.
The Shockwave Flash Object is shown as "Disabled" in Manage Add-ons.
When I right click it, the two buttons of "Disable" and "Enable" are both greyed out.
I tried IE 9 and now I am back in IE 10. In addition, I tried installing Flash Player 10 and 11 with the actual installation file (downloaded from Adobe) of both.
I used the un-installer from Adobe and deleted files every time before installing in:
C:\windows\system32\macromed\flash
C:\windows\syswow64\,acrp,ed\flash
%appdata%\adobe\flash player
%appdata%\macromedia\flash player
Nothing so far seems to make any difference. The two greyed out buttons of "Disable" and "Enable" are still there.
Is there an alternative to Adobe Flash Player?
Hillahant
4. Re: Cannot "Enable" Flash Player
hillahant Jun 2, 2013 8:03 AM (in response to pwillener)Here is my screen.
In your screen shot, you only have the "Disable" button at the bottom right corner. In the above screen shot, both "Enable" and "Disable" buttons at the bottom right corner are greyed out. The above installation was done with the indepentent installation file downloaded from Adobe.
By the way, I have both "Enable" and "Disable" greyed out if I just right click for the quick menu as you did. I can't seem to be able to get a snipe of that though.
5. Re: Cannot "Enable" Flash Player
pwillener Jun 2, 2013 9:37 PM (in response to hillahant)Hm, this is really strange; something must be wrong with your installation.
You have already used the uninstaller, then reinstalled. Can you try a complete clean install according to instructions in http://forums.adobe.com/thread/928315
P.S. any other IE add-ons, do the Enable/Disable buttons behave normally?
6. Re: Cannot "Enable" Flash Player
hillahant Jun 2, 2013 10:14 PM (in response to pwillener)I just did a complete clean install as per thread 928315 which is what I have been following every time before. The result, as expected, is the same. The 2 buttons are greyed out.
All the other IE add-ons has only one button, either "disable" or "enable" depending on their current setting.
The only 2 which behave the same way as the Flash Player, i.e. with both buttons greyed out, are Avast toolbar and Avast Browser Helper Object - 32 bit (which is understandable as the 64 bit equivalents are both enabled on my 64 bit Window 7).
The funny thing is that Adobe pronounces that all my "failed" installations have been "successful" the last few days. On the other hand, I did not have any problem with the installation on my laptop. It runs the same Window 7 and IE 10 as my desktop. The installation was indeed successful the first time with no effort. Maybe it is because it has other Adobe product (paid product).
What would one use other than Adobe Flash Player?
7. Re: Cannot "Enable" Flash Player
pwillener Jun 2, 2013 11:14 PM (in response to hillahant)Maybe something did not go correct during the installation, but that should produce some kind of error message.
Can you post the contents of the FlashInstall.log file from C:\WINDOWS\system32\Macromed\Flash
P.S. there is no other way to view Flash content on the Internet than with Flash Player.
Some sites (e.g. Youtube) offer their content in HTML5, but these are still very few.
9. Re: Cannot "Enable" Flash Player
pwillener Jun 4, 2013 12:03 AM (in response to hillahant)Thank you for the install log files; unfortunately everything looks perfectly normal.
Sorry, I have no more ideas; hopefully someone from the Flash Player engineering team will have a look at your problem.
10. Re: Cannot "Enable" Flash Player
hillahant Jun 4, 2013 12:47 PM (in response to pwillener)Hi, Pat,
Thank you for sticking with my problem. We tried.
It looks like that there is something within my desktop that prevents the truly successful installation of the Flash Player, even as Adobe was fooled into thinking it did install but in effect it did not.
Hillahant
11. Re: Cannot "Enable" Flash Player
Ghostchaser1961 Jun 21, 2013 4:44 AM (in response to hillahant)Hi you have exactly the same problem with mine... Did you get the solution anywhere else?
My stats read exactly the same as yours too.
This all happened on the last update from adobe but when you use a later or the one before after deletion it remains the same.
I noticed after the installer had finished files remained inc cache in c windows sytem32 adobe and macromedia.
I deleted these also and reinstalled adobe and it stays the same greyed out.
This one has me puzzled.
I have also found that there isn't another substitute for adobe flash player unless someone else can enlighten me.
Cheers
12. Re: Cannot "Enable" Flash Player
hillahant Jun 25, 2013 1:37 PM (in response to Ghostchaser1961)Hi, our friendly Adobe staff has just gone through the Adobe troubleshooting list which is the same as what I have tried myself previously, and with the same result. At least I can confirm that I did not miss any step!
The next step would be to contact Microsoft. I think I will let others do that. I (and Adobe) would be very interested to hear from anyone who is more persistent.
In the mean time, no Adobe flash player on my desktop. It is a nice sunny day out. Who wants to look at computer screen anyway?
13. Re: Cannot "Enable" Flash Player
Ghostchaser1961 Jun 25, 2013 5:16 PM (in response to hillahant)Hi,thanks for getting back, well again like you I followed the trouble shooting to the letter to no avail.
I guess then we have both have tried equally the same to resolve it and failed.
At least you have made it clear to me it's not my compi nor something i've missed so like you say see what adobe and or microsoft come up with (that is if they're bothered)!
The only adobe I can install is Air and Reader, Flash and Shockwave refuses to like I say since the last update.
Thanks again
14. Re: Cannot "Enable" Flash Player
mungox Jun 25, 2013 9:51 PM (in response to Ghostchaser1961)try installing in safe mode. just a thought.
15. Re: Cannot "Enable" Flash Player
Ghostchaser1961 Jun 26, 2013 1:43 AM (in response to mungox)Hi, Thank you for your suggestion.. I have already tried that and it doesn't make a difference however, you have prompted me to try another avenue.
I thought I had left no stone unturned but I haven't tried my thought.. I will get back on here and let the outcome known.
Thanks for that.
16. Re: Cannot "Enable" Flash Player
Leem1972 Nov 6, 2013 11:27 AM (in response to Ghostchaser1961)Hi,
Did you manage to solve the problem?
I have the same issue with my desktop (Vista installed). Tries everything, even reinstalled IE9 last night to no avail.
I have the same issue on my father in laws desktop also.
I removed AVAST and tried with Firewall down, still no joy.
I've had no replies in the thread I posted.
Cheers
Lee
17. Re: Cannot "Enable" Flash Player
hillahant Nov 6, 2013 11:48 AM (in response to Leem1972)Hi,
I tried everything. The Adobe “expert specialist” took control of my desktop and tried everything.
The short answer is nothing works. The only thing left to do is to replace my desktop someday.
I am using my laptop (much newer than my desktop) for anything that needs the Flash Player.
Ahant
18. Re: Cannot "Enable" Flash Player
Leem1972 Nov 7, 2013 2:41 AM (in response to hillahant)Thanks for your reply hillahant.
I'm amazed nobody from Adobe could fix it. There are loads of threads detailing this issue.
I may try and re-install Windows. There actually isn't much installed on these PC's. Fortunately my laptop with Windows 8 is working fine
19. Re: Cannot "Enable" Flash Player
hillahant Nov 7, 2013 7:45 AM (in response to Leem1972)Adobe has since put out several updates to the Flash Player but this problem persists. It is very disappointing that they have not resolved it. Perhaps it takes a lot of work and it only affects a small population hence their cost/benefit study says it is not worth the trouble.
If you are successful with this by re-stalling Window, let us know. Thanks.
20. Re: Cannot "Enable" Flash Player
eusch Nov 8, 2013 10:43 AM (in response to hillahant)This work for me Windows & IE 8 or 9.....uninstall with the adobe uninstaller, delete macromedia\flash folder, Download standalone installer for flash and for shackwave. As a local admin right click on the flash active X installer and run in compatability mode "XP SP2" THis will get past the "failed to register" issue. Install Full version of Shackwave and go test. Workaround but I wasted to much time on trying to fix with the methods provided by adobe.
21. Re: Cannot "Enable" Flash Player
hillahant Nov 8, 2013 12:52 PM (in response to eusch)Hi, eusch,
Thank you for making an effort to help. I have followed your steps for my IE 10, and unfortunately both the "Enable" and "Disable" buttons in "Manage Add-ons" are still greyed out.
I am glad to hear that it works for you with IE 8 or 9. I am too lazy to switch from IE 10 to 8 or 9. Like many others, I have spent too much time trying to get it working on my desktop. At this point, I will just use my laptop which has a successful installation of the flash player.
Just a clarification, when you say run in compatibility mode "XP SP2", you mean the "compatibility mode" in the tab "compatibility" when one right click and select "property"?
Ahant
23. Re: Cannot "Enable" Flash Player
eusch Nov 8, 2013 12:55 PM (in response to hillahant)If it doesn’t let you change it there…you need to run the trouble shoot compatabilty option when you right click on it.
24. Re: Cannot "Enable" Flash Player
hillahant Nov 8, 2013 1:33 PM (in response to eusch)I tried the troubleshoot compatibility thing. It recommends XP SP2. Then tried to install again but still not working. Oh well.
25. Re: Cannot "Enable" Flash Player
eusch Nov 8, 2013 1:36 PM (in response to hillahant)Sorry it’s a b*#&$ Fighting IE 10 now…what a mess
26. Re: Cannot "Enable" Flash Player
Leem1972 Nov 8, 2013 3:32 PM (in response to eusch)Cheers eusch and hillahant.
I've just uninstalled again and reinstalled using the settings in compatability mode and as admin but still the enable / disable are grey.
Its madness. I've got a desktop upstairs, hardly ever use it, its got XP on, think its got AVG but that works.
My laptop with Win 8 on works fine.
My desktop downstairs with VIsta / Avast on has grey enable / disable in addon for the flash
My father in laws desktop, XP / Avast on has grey enable / disable in addon for the flash.
I think they both used the recent Adobe update.
Unsure whether its Avast issue too but I've uninstalled that a few days ago, still no joy.
I've tried Google Chrome too a week or so ago and it didn't work but maybe I hadn't uninstalled Flash.
I'll try that now. . .
27. Re: Cannot "Enable" Flash Player
Leem1972 Nov 8, 2013 3:53 PM (in response to Leem1972)Installed Google Chrome.
That works.
Sounds a bit suspect to me though. It used to work with IE 9 prior to the last flash upgrade and now it doesn't but it does work with Google Chrome (which is advised to be installed) !!
28. Re: Cannot "Enable" Flash Player
ScubaGod Nov 29, 2013 1:16 AM (in response to Leem1972)I have tried everything suggested inthe thread but I still have gray buttons.
Glad to see I'm not alone. I thought it was something I did.
29. Re: Cannot "Enable" Flash Player
ditsche Apr 27, 2014 3:18 PM (in response to ScubaGod)I Solved the same problem with the help of my AVAST_Antivir_program, which allowed the user (Menu="browser_cleanup") to handle (=aktivateing/deaktivating/deleting) ALL IE_8_PLUGINS as descripted in my bugreport :
http://bugbase.adobe.com/index.cfm?event=bug&id=3705058
Hope that may be helpful for all, which have had the same problem
ditsche
30. Re: Cannot "Enable" Flash Player
Willlearniftaught Apr 27, 2014 5:48 PM (in response to ditsche)I want to thank Hillahant for starting this thread almost a year ago and Ditsche for solving the problem. To paraphrase Doctor McCoy: 'D**m it, Jim, I'm a lawyer, not a techie'. Following this thread made my head spin. It is ridiculous. I had no idea what Pat Willener and Hillahant were talking about. The "Translate" button does not translate their conversation into "plain speaking." I can not believe what Adobe has done.
I started my own thread and now realize that any answer to my question concerning my problem with downloading FlashPlayer will be unintelligible to me. Sad. As a lawyer, if I can not explain the Law to a client, the client either leaves or I send the client to another lawyer. This can not be done with FlashPlayer. Adobe is the only game in town. It is good to be king. But I certainly wil not sing the praises of this monarch.
31. Re: Cannot "Enable" Flash Player
Willlearniftaught Apr 30, 2014 4:52 PM (in response to Willlearniftaught)I would like to thank Mike M for providing me with a solution. He sent me a web address and it worked! Thank you, Mike!
32. Re: Cannot "Enable" Flash Player
alok singh May 4, 2014 11:13 PM (in response to Willlearniftaught)Hi,
Can you provide the web URL which solves this issue.
Regards
Alok
33. Re: Cannot "Enable" Flash Player
ditsche May 4, 2014 11:36 PM (in response to alok singh)In einer eMail vom 05.05.2014 08:13:28 Westeuropäische Sommerzeit schreibt
Regards
Alok
Hi ALOK,
I solved the problem with my AVAST! Antivirus-program, which is for free
to download and install from:
This Program has a Menu-Botton called "browser_cleaning" (you must remove
the sign at "Plugins mit guter Bewertung ausblenden") Now you can
activate/deactivate or delete all your browser_plugins (works for ALL browsers you
have installed/choosen).
I described my proplem and the solution in my bugreport
https://bugbase.adobe.com/index.cfm?event=bug&id=3705058
where you can find in Attchment two screenshots too (PROBLEM and
SOLUTION), which explain it.
Much luck
ditsche
34. Re: Cannot "Enable" Flash Player
iliansky May 27, 2014 12:55 PM (in response to hillahant)The problem is the group policy for the Add-Ons in the Internet Explorer: Internet Explorer Add-on Management and Crash Detection
The solution is setting the listed CLSID for the flash player class under the following key to "2":
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Ext\CLSID]
"{D27CDB6E-AE6D-11CF-96B8-444553540000}"="2"
{D27CDB6E-AE6D-11CF-96B8-444553540000} is the CLSID of the flash player (version 14.0.0.111) as registered in the registry of my PC with Windows 7.
Hope this helps.
ilian
35. Re: Cannot "Enable" Flash Player
SandraChung Jun 18, 2014 7:22 PM (in response to iliansky)I've been trying to install the latest version of Flash, and I keep getting the "Failed to register". Yes, I have done all troubleshooting. Uninstall, reboot, make sure all leftovers are deleted (
C:\Windows\system32\Macromed\Flash, C:\Windows\SysWOW64\Macromed\Flash , %appdata%\Adobe\Flash Player, %appdata%\Macromedia\Flash Player) rebooted.
Still got the error.
As for that windows registry setting you suggested, it's totally empty when I got this error.
The strange thing is, I can install it for Firefox without the error, but not IE. Yes, full admin access, run installation file as admin, the whole shebang.
