I have purchased two craft CD'S which are fine until I want to print out and then I get the above message.
I have enough menmort ti run programme. I have 98GB free. I am using the latest version of Adobe Flash Player and my laptop uses windows 7 64bit Firefox browser. I only a bit techy savvy and don't know what to do to sort out problem. Help Please?
the download is a self extracting zip file
right click on it and extract to here
if your more the two directories deep paste it into the root for now
then run hpzstub this will bypass the projector step
good luck
That sounds like you are using a very old Projector version? Do you know where that program is located on your computer?
You can download the latest Flash Player 11.7 Projector from http://www.adobe.com/support/flashplayer/downloads.html
hI
I do have the most up to date Adobe Flash Player -11.7.700.202 which i have unistalled and reinstalled to no effect. I running windows 7(64 bit) and Mozilla FireFox and Adobe sites states that this is the correct programe so I am at a loss . Isn't macromedia Projector a part of Adobe Flash Player
No I don't know where it is located on my computer. Can you tell me so I can advise you. Thanks for your help
Elaine
When you install Flash Player, it will only install the browser add-ons.
Flash Player Projector is a standalone player to view local SWF files. The latest Projector is called flashplayer_11_sa.exe
I cannot know where your current Projector is located; possibly on that CD? What else is on that CD - SWF files?
If these SWF files are played with Flash Player Projector, you could download the latest Projector, put it in with the rest of the Flash Player files, then associate your SWF files with that latest Projector.
On a 64-bit system that would be in C:\Windows\SysWOW64\Macromed\Flash
Don't hesitate to ask if you need more detailed instructions.
good luck
my mistake i though it was a hp scanner issue
