How do I setup Photoshop CC to save jpg/png
Jun 04, 2013 Jun 04, 2013
Hey guy's, i'm looking for plugins for Photoshop CC, I have a full license and need a plugin for jpg / png saves, Super PNG is installed in my plugins folder but it still doesn't give me the option to save. I'm just trying to type a font and save it .. can someone please help?
19.2K
Adobe
Adobe Employee ,
<< Moved to Photoshop Forum >>
Photoshop CC will not be released until two weeks from now.
What you have is not CC (which will be called Photoshop 14.x) but a copy of Photoshop 13.x (still "CS6") through the subscription/cloud model, but it's not "CC".
I'll address your user-error caused issue in the next post.
Your issue stems from your improperly installing old or redundant plug-ins in your Photoshop Plug-Ins folder, or in having pointed your Photoshop preferences to an "Additional plug-ins folder" with older plug-ins.
Go back and make sure that preference is NOT checked, and also go back and delete any plug-ins you installed in there.  Then re-launch Photoshop,
No Adobe plug-in belongs in the Photoshop Plug-Ins folder at all.  The  necessary Adobe plug-ins are already installed by default where you're not supposed even to see them, in the Required folder.  Only install freshly downloaded, updated and 64-bit compatible plug-ins from the third-party web site and follow their installation instructions precisely, preferably through their installer, if available.
Good luck.
Jun 05, 2013 Jun 05, 2013
Hello, and thank you for the help, I did everything you said to do, additional plugins folder was not checked, and I removed all the plugins from the plugins folder, it still isn't allowing me to save to jpg or png.. is there anything else I can do?
PNG is only available when the document is RGB or Gray, and is 8 or 16 bits per channel. Maybe you've been creating CMYK documents.
CMYK docs can be saved to JPEG. JPEG supports 8 bpc only. If your doc is 16 bpc then Ps CS6 will do an on-the-fly conversion from 16 to 8 bpc when saving to JPEG but earlier versions of Ps require you to first convert 16 to 8 bpc for JPEG to become available.
The SuperPNG plug-in should be put in folder:
/Applications/Adobe Photoshop CS6/Plug-ins/
Optional Adobe plug-ins which can be downloaded separately from the Photoshop installer should be put in there, too.
Assuming you're trying to save the right kinds of document, and PNG or JPG is just not showing up in the list of file formats during File - Save As, first and foremost, something is wrong with Photoshop, because you're supposed to be able to save these file types right out of the box, without any extra plug-ins.
Just to confirm:  If you create a new, 8 bits/channel RGB document, then try to File - Save As, do you see the entries listed below in the list of formats?
Rather than try to look for plug-ins, let's try to figure out why your Photoshop isn't providing you its native options.
Can you please choose Help - System Info from the Photoshop menus, copy the results, and paste them into a response here?  Usually basic problems can be spotted there.
-Noel
Oct 15, 2014 Oct 15, 2014
I am having saving problem!
Here is my system info:
Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
Operating System: Mac OS 10.9.5
System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 2300 MHz
Built-in memory: 16384 MB
Free memory: 9955 MB
Memory available to Photoshop: 15127 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=900, right=1440
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGPUs=1
gpu[0].OGLVersion="2.1"
gpu[0].MemoryMB=2048
gpu[0].RectTextureSize=16384
gpu[0].Renderer="NVIDIA GeForce GT 750M OpenGL Engine"
gpu[0].RendererID=16918311
gpu[0].Vendor="NVIDIA Corporation"
gpu[0].VendorID=4318
gpu[0].HasNPOTSupport=1
gpu[0].CompileProgramGLSL=1
gpu[0].TestFrameBuffer=1
gpu[0].OCLPresent=1
gpu[0].OCLVersion="1.2 (Jul 29 2014 21:24:39)"
gpu[0].CUDASupported=0
gpu[0].OCLBandwidth=3.28594e+10
gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
License Type: Subscription
Serial number: 96040863463087095056
Application folder: /Applications/Adobe Photoshop CC/
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Macintosh HD, 465.1G, 333.6G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-Ins/
Installed components:
   adbeape.framework   adbeape   3.4.0.29366   0.1160850
   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
   adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
   AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
   AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
   AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
   AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
   AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
   AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
   AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
   AdobeLinguistic.framework      19061
   AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
   AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
   AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   7.0.0.1786
   AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
   AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
   AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
   ahclient.framework   ahclient   1.8.0.31
   aif_core.framework   AdobeAIF   5.0.00   79.534508
   aif_ocl.framework   AdobeAIF   5.0.00   79.534508
   aif_ogl.framework   AdobeAIF   5.0.00   79.534508
   AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
   amtlib.framework   amtlib   7.0.0.249
   boost_date_time.framework   boost_date_time   7.0.0.0
   boost_signals.framework   boost_signals   7.0.0.0
   boost_system.framework   boost_system   7.0.0.0
   boost_threads.framework   boost_threads   7.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework   CIT   2.1.6.30929   151865
   CITThreading.framework   CITThreading   2.1.6.30929   151865
   dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
   dvacore.framework   dvacore   7.0.0.0
   dvamarshal.framework   dvamarshal   7.0.0.0
   dvamediatypes.framework   dvamediatypes   7.0.0.0
   dvaplayer.framework   dvaplayer   7.0.0.0
   dvatransport.framework   dvatransport   7.0.0.0
   dvaunittesting.framework   dvaunittesting   7.0.0.0
   dynamiclink.framework   dynamiclink   7.0.0.0
   FileInfo.framework   FileInfo   79.154511   79.154511
   filter_graph.framework   AdobeAIF   5.0.00   79.534508
   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
   LogSession.framework   LogSession   2.1.2.1785
   mediacoreif.framework   mediacoreif   7.0.0.0
   patchmatch.framework   patchmatch   1.2.00.31977   79.542390
   PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
   UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
   WRServices.framework
Required plug-ins:
   3D Studio 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   Angled Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 8.4.1 (200), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Camera Raw Filter 8.4.1 (200), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 14.2.1 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 14.2.1 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
   Entropy 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Extrude 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   IFF Format 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Ink Outlines 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 14.2.1 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Oil Paint 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
   OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
   Picture Package Filter 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Radial Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Read Watermark NO VERSION - from the file “DigiRead.plugin”
   Reticulation 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 14.2.1, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shake Reduction 14.2, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
   Shear 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spatter 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   STL 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Underpainting 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
   Water Paper 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wind 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wireless Bitmap 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Kuler
   Adobe Exchange
Installed TWAIN devices: NONE
Check your image mode and bit depth.
