Coldfusion 9 and FamilyLink - Web Classroom
Guest
Jun 03, 2013 Jun 03, 2013
I'm using CF9 on a webserver which is also using FL and WC. I can't get all three to work at the same time. I can get CF to work but then FL and WC won't work. I get runtime error while trying to use FL and Internet 500 error on WC.
It has to do with the web server configuration tool, I add a webserver to add the CF applications but it knocks out the other two programs. If I remove the webserver FL and WC work fine. I think it has to do with JRUN but I'm such a newby I have no clue how to fix this so everything plays well together. FL and WC use java pretty heavily. So when I add the webserver to run the CF applications am I knocking out the IIS? OH and I'm using Windows Server2008 RT OS and IIS7.
all help is much appreiciated
683
Guest
OK, does anyone know IF and HOW I can change the default port Coldfusion uses from 80 to 110?
Adobe Employee ,
Jun 05, 2013 Jun 05, 2013
Hello Techwomantoo,
Thank you for your post. Please try the following steps to change the port:-
  1. Open Internet Information Services (IIS) Manager.
  2. Select the Web site that you wish to configure.
  3. In the Action pane, click Bindings.
  4. Click Add to add a new site binding, or click Edit to change an existing binding.
  5. Click OK to apply the changes.
Please note that, the port you are going to change (110 in this case), should not be in use by any other service/process.
Anit Kumar
Guest
Jun 07, 2013 Jun 07, 2013
Thank you,I understand how to change it there I was a way to change the actual program that wants to use port 80.
Adobe Employee ,
Jun 12, 2013 Jun 12, 2013
Hello Techwomantoo,
I am not sure if you are looking for this one, but you can refer to http://help.adobe.com/en_US/ColdFusion/9.0/Installing/WSc3ff6d0ea77859461172e0811cdec18c28-7ffc.html to change the built-in port.
Please let us know, if this doesn't help.
Anit Kumar
Documentation
