Show 5 replies
1. Re: Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
JSS1138 Jun 6, 2013 8:02 PM (in response to nikiv1984)My best guess is something amiss with the graphics card or driver.
2. Re: Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
petergaraway Jun 8, 2013 9:09 PM (in response to nikiv1984)This bug should be resolved in NVIDIA's next release. Try rolling back to the previous driver version.
Peter Garaway
Adobe
Premiere Pro
3. Re: Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
nikiv1984 Jul 13, 2013 7:19 PM (in response to petergaraway)Hello, NVIDIA released driver update in the meantime, but the problem is still here. It's really annoying... Hope it'll be fixed soon.
4. Re: Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
Steven L. Gotz Jul 13, 2013 10:13 PM (in response to nikiv1984)You are probably better off using the scaling in the Motion Effect anyway so you can adjust the image to a little larger if you want without having a problem. It is easy enough to type in the number 62 instead of right clicking and choosing Scale to Frame Size.
5. Re: Wavy vertical lines distort top and bottom when I use Scale to frame size in CS6
pgaraway@adobe.com Aug 22, 2013 2:08 PM (in response to nikiv1984)This has been fixed in Nvidia driver 320.78.
Peter Garaway
Adobe
Premiere Pro
